evodan2004's attempt at 9s take 1... failed
Old May 23, 2011 | 08:04 PM
  #31
06MREvo's Avatar
There is a video or 2 of Emery from STM using the e-brake while launching in the white 04 RS evo...I've seen a couple other people do it too...
Old May 23, 2011 | 08:12 PM
  #32
EvoDan2004's Avatar
what do you do just hold it up and when you start to release the clutch where its starting to grab let the E-Brake go?
Old May 23, 2011 | 08:28 PM
  #33
evodude32's Avatar
I might make a quick video guide of how to launch using the e-brake or hand brake. It's simple really. Just takes a bit to get used to, your 1st time you will be confused and mess up, but after awhile you get used to it and it comes 2nd nature.
Basically what you do is bring the car up to the pre-stage, pull the ebrake up and let the clutch out till you barely feel it grab, use the e-brake to move into the full stage beam leaving the clutch pedal where it's at (that friction point where the clutch is slightly engaging) Bring the car on the 2step, then when your ready to go, let go of the e-brake and the car will start to move, once you feel it move, let the clutch out and away you go.
Old May 23, 2011 | 08:32 PM
  #34
EvoDan2004's Avatar
ill give it a shot. ill also get some vid of my driving so you guys can laugh at me haha. ill do it the way i have been and with the ebrake. worth a shot
Old May 23, 2011 | 09:29 PM
  #35
Wheatley's Avatar
If you ever hear the term preloading thats what evodude is explaining to you. Most if not all of the fast guys that don't break much do it.
Old May 23, 2011 | 09:53 PM
  #36
evodude32's Avatar
I posted a how-to video on preloading here dan.
https://www.evolutionm.net/forums/dr...ml#post9342011
Old May 23, 2011 | 10:02 PM
  #37
EvoDan2004's Avatar
ok ill watch it . thanks man. means a lot to me
Old May 23, 2011 | 10:04 PM
  #38
evodude32's Avatar
Np problem man! I wanna see you get that 9 second slip!! I fought for mine and it felt like it took forever! So I know your frustration.
Old May 23, 2011 | 10:10 PM
  #39
EvoDan2004's Avatar
thanks man. to do this on are own is rough for sure. getting tips from experienced drivers who have done it definitely will help. i just hope the car has the ***** to do it. time and practice.
Old May 25, 2011 | 04:31 AM
  #40
raiceboi697's Avatar
the cars got it, driver mod is the biggest thing.....
Old May 25, 2011 | 01:30 PM
  #41
Black Momba's Avatar
r i p to that axel on to the next!! nice pass though
Old May 25, 2011 | 01:33 PM
  #42
red4k's Avatar
I love island. let me know when youre going back so i can go too!
EDIT noliftshift!ftw
Old May 25, 2011 | 01:43 PM
  #43
EvoDan2004's Avatar
thanks. yea i think it has it too. i think if it does it it will be a 9.999 pass. and i am ok with that. i do not NO LIFT SHIFT so that probably will hold me back some as well. last time i did NLTS i blew apart my trans in 4th gear. so i been a bit hesitant to try it again.
thanks man.
i plan to go back as soon as the car is fixed. i sent the rear back to T.R.E. he said he will try to get it back to me by next friday. so if that happens ill be back sunday at the track.
Old May 25, 2011 | 01:44 PM
  #44
EvoDan2004's Avatar
HAHA your edit was on my mind. haha
Old May 26, 2011 | 07:01 PM
  #45
EvoDan2004's Avatar
i know this is not my build or ''project'' thread but im bored as hell right now and figured i would post it here as well too.
got some parts updates for the car. nothing special. just figured i would add in what i got.
while the car is down ill be putting a few of these parts on.
ARP extended wheel studs. i will be making the stock lug nuts open ended so the still work with stock rims.
CBRD Ti lug nuts. these will be used for the RX-7 rims and QTP tires
Custom made RX-7/stock evo hub 20mm spacers.
STM fuel pressure regulator kit.
and of course new rear axles. lol
here is some pics.
CBRD Ti lug nuts.
wheel spacers.
ill get pics of the STM FPR kit and ARP studs when the arrive in the mail.
