Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
Tom, what is your rev limiter set to??
Not bad for 1 run, nice job finally running 10s! I agree, your MPH is definitely slacking somehow. Your top end is a lot better than mine but when I went to the track last spring I was trapping 96mph in the 1/8th. That was 93 oct, stock block & a BBK-B, around 27-28psi.
nothing was removed.. infact i even left a heavy battery jumper in the car
.. it was a last minute run type deal and i was not ready 100% and rushed everything.heres the video.
Ya it hit the limiter in 2nd. also first, but i think it always does in 1st. everywhere you hear a pop / backfire is limiter being nailed. Ya the 1-2 was embarrassingly horrible. i hit limiter i think 2 times in 2nd then shifted.. ive done a decent 1-2 before on street tires and if you hit 2nd just right it feels like another mini launch. this pass felt like a bog. the limiter is set to 8400 in this pass, but i remember only going to 8000 in 3rd gear. other then that im happy for the 10, but the mph im not happy with.. but i guess since theres the boost and afr i have hope its still in there hiding somewhere.
can you enable NLTS and log it and compare the time it takes with and without for me? im curious how much difference there is from nlts'ing and speed shifting.
if not ill do it myself, but i figure you already have track logs of speed shifting, so nlts should be easy to test for you. its easy to enable in the rom its literally changing a 0 to a 1 and reflashing.
FP White, nice! That's a good ET for that MPH...any idea what the car weighs?
keeping you busy BJ LOL!
tscompusa (Tom) / 9/8/12 / TSCOMPTUNED / Evo 8 / FP BLACK, E85, BR 2.3, V7 SD, 35psi, 3200lb & Hoosier qtp / 10.839ET
tscompusa (Tom) / 9/8/12 / TSCOMPTUNED / Evo 8 / FP BLACK, E85, BR 2.3, V7 SD, 35psi, 3200lb & Hoosier qtp / 133.16MPH
5LEEPERISAH23I / 9/8/12 / TSCOMPTUNED / Evo 9 / FP BLACK, E85, TSCOMPTUNED 2.4L, V7 SD, 3366lb, Junk tires, shifted into 5th / 11.045ET
5LEEPERISAH23I / 9/8/12 / TSCOMPTUNED / Evo 9 / FP BLACK, E85, TSCOMPTUNED 2.4L, V7 SD, 3366lb, Junk tires, shifted into 5th / 130.39MPH
