Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
5LEEPERISAH23I / 8/19/12 / TSCOMPTUNED / Evo 9 SE / FP BLACK, E85, TSCOMPTUNED 2.4L, (Tephra v7 Speed density), 3366lb & Junk tires & shift into 5th / 11.224ET
5LEEPERISAH23I / 8/19/12 / TSCOMPTUNED / Evo 9 SE / FP BLACK, E85, TSCOMPTUNED 2.4L, (Tephra v7 Speed density), 3366lb & Junk tires & shift into 5th / 127.03MPH
DarkRogue / 8/19/12 / TSCOMPTUNED/ Full Weight + Sound system / Evo 8 GSR / FP BLACK, 93oct, BR 2.4L, (Tephra v7 Speed density), / 11.486ET
DarkRogue / 8/19/12 / TSCOMPTUNED / Full Weight + Sound system / Evo 8 GSR / FP BLACK, 93oct, BR 2.4L, (Tephra v7 Speed density), / 120.69MPH
dont have his timeslip but theres his time lol.. both my customers competed against each other in that race.
Slip from above run - mine and the other guys numbers
Id like to add - mine is a "full" weight street car. Complete with plywood deck for sub/amp assembly, 7" in-dash dvd unit, leather, ac, sunroof, etc.
Drove it to the shootout got 23mpg (220miles one way), dropped tire pressure to 25psi. Made passes. Filled back up to 32. Drove home. Drove it to work the next day.
List is updated & finally has 20 ETs & MPHs on it!! As of 8/28/12 our fastest & slowest times are...
ET - 9.436 (Fastest) to 11.791 (Slowest)
MPH - 147.01 (Fastest) to 117.86 (Slowest)
You can take a stock turbo off your car & swap one of these right in it's place. Will bolt up directly to a stock exhaust manifold, 02 housing, downpipe. There was some debate when ATP first released these stock turbos but everyone ended up agreeing that they are a stock appearing turbo & can be included in this list. Not like these turbos are beating up on everybody, hell an FP Red is king of the list!
Also, I am pretty positive the only turbo in ATP stock appearing line up that flows more than an FP Black is the ATP GTX3582R...
i finally ran a 10! i was hoping for a lot more mph though.. but i only got to run once so i think i did ok.. the boost was about 34psi for some odd reason it went 2psi less and 11.1 afr pig rich popping inbetween shifts etc.
i need to do some drag racing simulation at my house on backroads and dial the boost in from 6k+.. or not go to the track with 1hr to spare like a dumbass and only get 1 pass in.
tscompusa (Tom) / 8/30/12 / TSCOMPTUNED / Evo 8 / FP BLACK (34psi), E85, BR 2.3, (SD), 3250lb & Hoosier qtp / 10.949ET
tscompusa (Tom) / 8/30/12 / TSCOMPTUNED / Evo 8 / FP BLACK (34psi), E85, BR 2.3, (SD), 3250lb & Hoosier qtp / 131.09MPH
Not bad for 1 run, nice job finally running 10s! I agree, your MPH is definitely slacking somehow. Your top end is a lot better than mine but when I went to the track last spring I was trapping 96mph in the 1/8th. That was 93 oct, stock block & a BBK-B, around 27-28psi.
