Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
Old Apr 14, 2012 | 04:16 PM
  #121
V8HAHA's Avatar
First gen FP Green
Stock 2.0
Stock tranny w/ exedy twin ( 3rd and 4th gear syncros shot, cant no lift shift)
Comp 280 cams
E85 tuned 26psi tappering to 18psi
Hoosier et's
Car has trapped 121mph spinning thru 3rd but that was before my tranny took a crap. I went 11.8 @114 in this run loosing 6mph due to bad syncros and lack of no lift shifting.
run was on 1/29/12 @ IFO in Tucson AZ track alt. 2856ft
Old Apr 15, 2012 | 05:01 PM
  #122
BOOSTINAT30PSI's Avatar
For the ET list
Boostinat30psi/ March 15th 2012 1st time EVER at the track/ Sponsored by myself/ Evo 8 RS/ 2.3 Stroker Journal bearing FP BLACK GSC S2 cams stock intake mani, tb, trans, and tcase 25psi on pump and street tires full weight street car/ 11.717
For the MPH list
Boostinat30psi/ March 15th 2012 1st time EVER at the track/ Sponsored by myself/ Evo 8 RS/ 2.3 Stroker Journal bearing FP BLACK GSC S2 cams stock intake mani, tb, trans, and tcase 25psi on pump and street tires full weight street car/ 120.32mph
Old Apr 15, 2012 | 05:03 PM
  #123
oh and i did this at island.
Old Apr 15, 2012 | 05:08 PM
  #124
4g63evoeight's Avatar
MPH seems kinda of low, how much power is the car making? what fuel?
Old Apr 15, 2012 | 05:09 PM
  #125
i had issues on the dyno 2 thursdays ago... so i am just street tuned at the moment and on 93 pump
Old Apr 15, 2012 | 05:10 PM
  #126
problem is my rev limiter is set at 7600 and i am forced to throw it in 5th gear!
Old Apr 15, 2012 | 05:11 PM
  #127
vmrevo9's Avatar
Veteran: Air Force
not bad especially for the first time out and with the new setup.
great job boostin
edit:
once you get retuned can the motor handle 8K rev limit?
Old Apr 15, 2012 | 05:13 PM
  #128
thank you so much. my first run was a 12.3 i believe... mid 2 second 60 ft... i never launched an awd before and all i did was bog. the car only makes 2psi on the 2 step... and i was sooooo nervous. lol
Old Apr 15, 2012 | 05:15 PM
  #129
here is a vid of one of the 11 second runs... i have the best friends yet the worst for taking pics and videos
http://youtu.be/FRoBOy8HzHs
Old Apr 15, 2012 | 05:16 PM
  #130
vmrevo9's Avatar
Veteran: Air Force
man i still get nervous everytime i staged lol
either way with some more seat time you'll definitely see a big difference!
edit:
your friend is really excited lol
Old Apr 15, 2012 | 05:19 PM
  #131
traction owned me in some runs
Old Apr 15, 2012 | 05:24 PM
  #132
vmrevo9's Avatar
Veteran: Air Force
what psi were your street tires set to?
when i finally hit my 11s passes i had new street tires on and they were set to ~25psi and i feel that my shifting was quicker.
the tires help make a big difference. before i used to shift and the tires would break traction . with the new tires it definitely helped. they're not slicks but it work
Old Apr 15, 2012 | 05:25 PM
  #133
i was at like 30psi on the tires hankook evo
Old Apr 15, 2012 | 05:31 PM
  #134
vmrevo9's Avatar
Veteran: Air Force
definitely need to drop tire pressure next time out.
Old Apr 15, 2012 | 05:32 PM
  #135
ill be sure to do that
so many things held me back... but overall happy
