Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
Well went back to the track today. I was having traction issues on all 3 runs but on the second pass I somehow worked the clutch when the front tires started spinning and it hooked. I hit every gear and almost got into the 10s. I ran an 11.093 @ 130.63. If the tires didnt spin it wouldve been a 10 second pass. Next year the drag slicks will go on. Its kind of hard to see but here is picture.
Yea built block bored .020 over with 9.1 pistons. Running 40psi with 17 up top. I think I have a boost leak past 25psi but with my compressor I cant get past 23psi for testing. Next year the slicks will go on and 10s for sure
5LEEPERISAH23I / 12/2/12 / TSCOMPTUNED / Evo 9 / FP BLACK, E85, TSCOMPTUNED 2.4L, V7 SD, 3366lb, Junk tires, shifted into 5th / 11.016ET
5LEEPERISAH23I / 12/2/12 / TSCOMPTUNED / Evo 9 / FP BLACK, E85, TSCOMPTUNED 2.4L, V7 SD, 3366lb, Junk tires, shifted into 5th / 133.68MPH
first, when i saw you as the most recent post in here I was expecting some big news from your car, lol.
2nd, this slip is the guy that was bragging on walking away from a pullied ZR-1 or something like that?
