Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
Does not improve my position but im stoked to get the 120mph monkey off my back especially with the stock evo 9 gearing on smaller sized turbo.
Turbofig / 10/13/12 / Evo 9 / FP White, E85, Stock block, M2 cams, stock 235/45/17 tires / 120.076mph
Ronnie Size - 8/19/12 - VRSF - Evo 9 - FP RED, built 2.0, pump gas, street tires, GSC S2 - 11.420 @ 120.24mph
Slip Break down:
60ft 1.701
330 4.750
1/8 7.333
MPH 96.11
1000 9.550
E.T. 11.420
MPH 120.24
Slip Break down:
60ft 1.701
330 4.750
1/8 7.333
MPH 96.11
1000 9.550
E.T. 11.420
MPH 120.24
binky / 6/20/2012 / Myself / Evo 8 / FP BLACK, ER 2.0, GSC S3's, V7 SD tune by Dynotech Tuning, Full weight, 93 OCT @ 34 PSI / 11.71 @ 122
Need to work on my launch....new tires needed.
-Bink
-Bink
Nice job guys, will update later today...
Hey Bink, can you post your full MPH for me, 122.XX...Thanks
I think I still have it....it's at home I'll try and find it tonight.
I know my last time at the track, even though I wasn't faster than what I posted above, I gained 28 MPH in the back half, which is pretty awesome
-Bink
-Bink
Mine? heres the slip:
this was my first all out run on these tires/clutch/setup. the next run i upped the two step to get rid of a nasty bog off the line (rpms dropped to about 3400rpm iirc), but snapped the front diff on the run.
This is with peak boost being at 33psi on the black. shooting for 10's with a good launch (full weight ssl except front and rear crashbeam, small batt. removed spare tire)
I'm jealous....I need a 1.6 60' time.....
I think its because my tires are the same from when I bought the car in 2007...that's my story and I'm sticking to it.
-Bink
-Bink
Good job guys
. I'm hoping to hit the track this Sunday and hopefully get into the 10s still on street tires. It will probably be the last time this year I get out to the track. If not it will happen next year when I have some QTPs mounted on the Evo
