Evo 8 4th gear conversion in evo 9
Old Mar 27, 2013 | 07:20 PM
dtrackstar's Avatar
I understand the advantage of an evo 8 4th gear as oppose to an evo 9. I was curious, if all things remaining the same (power and weight), would et or mph be affected by the conversion. And if so, how?
Old Mar 29, 2013 | 06:26 PM
jmcmill3's Avatar
i would have to say so, my 9 would run out of gear in the 1/4 and raising the limiter etc etc.. resulted in the same thing, best times were running the stock block out to 8500 rpms and it still would bang the limiter well before the lights..
ive switched to an 8 3rd and 4th, but have not been back to the track yet, plus ive changed too much for a "good" comparison
Old Mar 30, 2013 | 04:04 PM
dtrackstar's Avatar
So are you saying it wouldn't effect et or mph ?
My car is passing the line at 117+ and after 7k rpm for reference. I'm trying to break into tens on stock turbo which is out of air at 7500.
Old Mar 31, 2013 | 08:24 PM
jmcmill3's Avatar
It should affect both, ive seen evo 8s with 390-425 whp trap120-122 on 9 turbos.
Old Mar 31, 2013 | 08:49 PM
dtrackstar's Avatar
Got yah. Thanks
Old Apr 5, 2013 | 01:28 AM
GotWheelHop's Avatar
Got yah. Thanks
Just from switching the gear ONLY, I would think the car would ET slower, but possibly trap slightly higher. My reasoning is that since the gear is longer, the car needs more power to pull the gear in the same amount of time. Since you aren't bumping power with the gear swap, it should take longer to run through 4th. Conversely, you are accelerating for a longer period of time, and also not running out of gear before the trap so your MPH might go up.
I might be way wrong, but in practical terms it seems to make sense. Let me know how it goes if you did the swap for some reason.
*edit* just re-read your post. Your ET will go down and your MPH will go up. You are on a stock turbo which makes it's peak torque earlier in the rev range, so you will actually be able to take advantage of the turbo's sweet spot for longer.
Last edited by GotWheelHop; Apr 5, 2013 at 01:31 AM. Reason: reading comprehension > me
Old Apr 5, 2013 | 06:31 AM
dtrackstar's Avatar
Your rationale makes sense. I hope it's right; I plan to convert next season.
mrm95
Oct 16, 2014 07:50 AM
ranz
11
Nov 22, 2012 12:58 PM
Brsox10288
18
Mar 7, 2012 10:04 PM
dxbevo9
18
Jan 20, 2009 04:56 PM
dxbevo9
12
Sep 22, 2007 08:24 AM
