evo 8 4th gear...why??
Old Sep 21, 2007 | 05:20 PM
dxbevo9's Avatar
i tried searching with no luck...(psst. wartalon!)
why do evo IX owners with (6spd) prefer to put and evo8 4th gear(5spd) when rebuilding their gearbox??
thanks in advance
Old Sep 21, 2007 | 05:22 PM
electricevo's Avatar
Its a longer gear so you can hold 4th through the traps longer. the evo IX has a shorter 4th
Old Sep 21, 2007 | 05:23 PM
EvoDan2004's Avatar
most people drag race so the 5 speed is better then the 6 speed.
4th geaqr in the 6 speed fails alot
5 speed is stronger then the 6 speed
thats all i know
Old Sep 21, 2007 | 05:24 PM
dxbevo9's Avatar
so i am not mistaken....you could actually put a (5spd) 4th instead of the shorter (6spd) 4th??!!
thanks electricevo
Old Sep 21, 2007 | 06:11 PM
dxbevo9's Avatar
guys i need an answer:
does the (5spd) 4th fit instead of the (6spd) 4th??
Old Sep 21, 2007 | 06:21 PM
sekula's Avatar
YES! didn't they just tell you that in the above posts??? People swap their 6 speed trannies to 5 speed trannies
Old Sep 21, 2007 | 06:35 PM
dxbevo9's Avatar
i might have not been clear asking my question...
i wanna keep my six speed tranny..but swap out the 4th..is that even physically possible?
Old Sep 21, 2007 | 06:39 PM
flipguy88's Avatar
You should email Jon at TRE at jon@teamrip.com and ask him. Just sent off my tranny to get rebuilt to a stage 2. But I believe what you want is physically possible, but just to make sure you should ask him.
Old Sep 21, 2007 | 06:42 PM
dxbevo9's Avatar
thanks flipguy88
i will email...
however if anyone else would like to chime in..please be my guest!!
Old Sep 21, 2007 | 09:02 PM
vwjeff's Avatar
Its not possible to put a 5speed 4th into a 6speed box, the 5speed gear is wider.
I didnt buy am MR cause of the 6speed, I hate shifting as it is And later found out 6's are nothing but trouble... LUCKY ME
I (Buschur) swapped my IX 4th with an VIII so I could trap better.
Old Sep 21, 2007 | 09:19 PM
dxbevo9's Avatar
thanks vwjeff
Old Sep 22, 2007 | 05:02 AM
mudduck's Avatar
So, correct me if I'm wrong, but...
I understand the Evo VIII's 4th gear is longer and allows for higher trap speeds at the drag strip before having to shift into 5th, but for str**t racing (OMG!!11!!! ):
wouldn't an Evo IX with the IX 4th gear pull on an otherwise identical Evo IX with an VIII 4th gear until about 114-115mph (or wherever you have to shift a stock IX into 5th...) ???
Assuming yes, who would win in a race to 140? (both cars now in 5th, the evo with the VIII's 4th gear got to stay in 4th longer, while the stock Evo IX has been in 5th for a while)
Old Sep 22, 2007 | 08:24 AM
dxbevo9's Avatar
assuming both cars are the same except for the gears...the evo with the VIII's 4th being in 4th would pull on the EVO with the IX 4th....
correct me if i am wrong
Llew
Nov 16, 2016 05:05 AM
razorlab
Jul 1, 2014 06:15 AM
Vishnu_Evo8
Jan 21, 2007 06:25 PM
razorlab
19
Oct 14, 2006 08:24 AM
bmaga123
24
Nov 17, 2004 09:59 AM
