New Best!!
Old Oct 4, 2004 | 08:33 PM
  #46
lil'evil_evo's Avatar
Very nice with those mods. I am very similar besides the 264's. Which I hope to have soon.
Old Oct 4, 2004 | 10:04 PM
  #47
Geo@EvoStore's Avatar
Originally Posted by TURBODAWG
I haven't been to the track since the early spring. I hope to get back to the track soon. The car feels a good bit faster and smoother since I installed the Greddy FMIC and the Greddy Ti exhaust, even with the RT cat in place instead of the UR test pipe. I think 118 mph runs shouldn't be a problem even in the heat, unless it is 90+ degrees. The other runs were made with the stock FMIC and cool weather. I think with the Greddy FMIC and slightly warmer weather, I shouldn't be too far under power compared to the cooler nights back in March.
Brian
Sounds good keep us updated. That is definately impressive.
Old Oct 5, 2004 | 10:51 PM
  #48
KIDBANGA10's Avatar
Question
I was running 23 psi peak, with a sustained boost of around 21 psi. I was using and still am using a Greddy Profec B spec 2. I didn't have a wideband hooked up at the time, I was tuning with Pocketlogger. I kept leaning it out on the 110 octane fuel until I got .88 to .90 on the O2 voltage. I also monitored the timing to make sure that I wasn't knocking. The timing stayed good. I now have a wideband, and would estimate that I was running ~12.5 to 12.2 air fuel ratio.
Brian
What kind of pocketlogger are you using? And what are you using to monitor timing? Great times
Old Oct 15, 2004 | 01:36 PM
  #49
TURBODAWG's Avatar
I have the pocketlogger. I think the webstite is www.pocketlogger.com or just search for pocketlogger. It reads alot of the OBD2 sensors, and timing advance is one of the parameter it reads. So I was using the pocketlogger to log RPM, TIMING, O2 voltage, and Throttle position. You can view the datalogs on the palm pilot and can download the datalogs on the computer when you get home and see the raw data and graphical format. It is a very nice little tuning tool.
Brian
StreetThisEvo
Sep 14, 2015 10:59 PM
David Buschur
680
Oct 23, 2014 11:49 AM
David Buschur
114
Feb 4, 2013 09:02 AM
StreetThisEvo
Jul 2, 2012 04:55 AM
Scot
Aug 25, 2003 04:22 PM
