whats my chances against this STi?
Old Apr 10, 2004 | 02:12 PM
  #46
Noize's Avatar
EvoM Administrator
Originally posted by fledis
I believe the outcome of the race was determined by the driver's, and not so much by the cars. What were the trap speeds of each car? With those mods, the STi is easily good for 12's. I've gone 13.3@98(messed up the 4-5 shift) and 13.3@101(messed up launch) in my stock STi.
I also don't think 5th gear is a problem because you're just getting into it at the end of the 1/4, shouldn't have too much effect on times....might drop the trap speed a little.
The 4-5 upshift definitely has an effect on trap speed, because it has the same gigantic step that the 3-4 has on the WRX, which I used to own.
Awhile back when I had only $500 in mods, I went 12.91@107mph. Most WRX friends that run 12.80s are only trapping 105mph. STi acceleration from about ~95mph-120mph is pretty tepid. From ~120mph-135mph, they're a good amount stronger than the Evo, but obviously, that's not really usable speed unless you're on a roadcourse with a pretty amazing straight.
I like the STi, but its gear spacing is its achilles heel. Other problems like its small stock turbo and injectors are much less expensive problems to address.
Old Apr 10, 2004 | 03:16 PM
  #47
fledis's Avatar
I don't seem to notice a slow down in acceleration after my 4-5 shift, but I'm not in it too long.
I think the biggest factor in the lower trap speeds in an STi is the torque. The torque the STi generates allows it to run faster times at lower speeds. An STi has run 12.1@113 w/ 319whp. Most STi's that run 12.5-12.8 are trapping 105-108. I believe similar running Evo's are trapping 110+.
Just an idea.
Old Apr 10, 2004 | 07:26 PM
  #48
Fourdoor's Avatar
Originally posted by waitin4ozzyevo
Our fuel is 98 Octane in Australia (SHELL OPTIMAX)
That would be 98 RON. That is aprox the equivelent of 92 or 93 octane in North America where we take an average of RON and MON octane numbers.
Keith
Old Apr 12, 2004 | 03:30 PM
  #49
EVO8 WHOA's Avatar
my trap speed was 105 on the 12.777 with a 1.726 60ft and i believe his trap was 106.XX on his 13.3. i noticed on all the different launches that i was being able to use my 4th gear more and more as the night went on. i think if i coulda ran maybe 2-3 more runs i coulda hit 12.5-12.6. im gonna go back with some 100 no lead gas and my new Pruven fmic and rmr piping, and act clutch and some real tires! i was on winter tires that night haha
Old Apr 16, 2004 | 06:59 PM
  #50
Kris in the STi's Avatar
Just an idea.
i did 12.5@110.3 with a leaking tb hose and a 1.76 60ft
and 12.8@108 with only 200 bucks invested
i think people are running lower traps cuz they suck at shifting into 5th fast
i think the STi's short gearbox is perfect....always in the powerband.......it sucks for dragracing....but turning...the short 2/3/4 gears and tq to keep turbo lag out....never caught in a bad spot.....
the achilles heel(sp?)s are the tires.....the a046's are FAR superior to the re070's.....by no comparison......drag racing the re070's are perfect..i did a 1.674 60ft my 3rd time racing the car....but turning....the a046 dominates
Old Apr 16, 2004 | 07:03 PM
  #51
and also......
my 5th gear(98~135) is very strong.....when i was stock roll racing evo's(40 punch)...i didnt do that much against them until about 60...and then id pull out...and as soon as i shifted into 5th......i pulled very hard.....i raced atleast 7-8 different stock evos when i wass stock.....and sometimes i would pull earlier...but everytime..5th gear....i walked away hard
Old Apr 18, 2004 | 05:10 AM
  #52
bluesteel's Avatar
Hi, new here..
this thread interested me so this is my first post.
I believe the fastest STi is ESX's STi-- and I know a few people who have run 12.9's stock at around 1200ft elevation, however, I ran a 13.5@100 stock at 5800ft with only 3 runs with the STi under my belt. Also a friend of mine did a 13.3@101 stock at 5800ft. So I think the STi is does pretty welll in the 1/4, it's just the driver's that suck ***.
So what was the result of the race? EVO's are nice and they are ready to make power with a few modifications. good things.
Clarence
Old Apr 18, 2004 | 09:03 PM
  #53
EVO8 WHOA's Avatar
well i wasnt impressed on their potential when i found my friends that have them cant go over 16 lbs, and its hard to adjust the boost controllers they have so it doesnt spike, because when it does, the ecu f***s their timing up and makes them slower than ****, i will stick with the 4G63, tested, pruven, and very modable.
Old Apr 19, 2004 | 01:20 AM
  #54
100 dollar part fixes the boost problem
you cant run mroe than 16.5xxx lbs of boost for more than 1.xx seconds or the ecu triggers boost cut
but its easily fixed
and its not hard to tune the EBC if you know what youre doing
if youre a no talent @ss clown...then yeah yorue gonna spike and hit boost cut
but yeah....safe mode sucks cuz the ecu wont advance timing, or add fuel....and that sucks....a lot
Old Apr 19, 2004 | 01:21 AM
  #55
did you only trap 105 on115 octane???????????
Old Apr 26, 2004 | 10:59 PM
  #56
A418t81's Avatar
i personally think its refreshing to see that both Evo and STi owners can accept the fac that both cars have the capability to generate lots of power. Every now and then I pop over to NASIOC and see what the 2.5L forum is up to. Those guys think I'm FOS when I politely correct them and tell them that ~300 whp in an Evo is only $1k away (dynoflash, 3" TB, MBC).
Meh, their loss
Old Apr 27, 2004 | 06:23 AM
  #57
EVO8 WHOA's Avatar
yes that 105 trap speed is a bad clutch that smells bad and slips like a bi***, i get my new one next week and will run it again
Old Apr 27, 2004 | 05:34 PM
  #58
you should run him....both on 93 octane
Old May 2, 2004 | 06:27 PM
  #59
rACerS's Avatar
my bother in-law has a sti with full exhaust, bov, and intake. He just ran a 12.69 @ 106mph last week. I was pretty blown away by this. he still cant keep up with the evo
Old May 6, 2004 | 09:31 PM
  #60
EvolvedfromaWRX's Avatar
he means 5 inch cause its bellmouth and hes talking out his bum bum.... you should smoke him
Ralli_Red
Jul 20, 2015 07:28 AM
GreeceS13
Feb 22, 2015 06:31 AM
Photool
Lancer Aftermarket Forced Induction Tech
12
Aug 9, 2010 11:52 AM
sekula
Jun 9, 2007 07:42 PM
