Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Rear diff clunk after a hard upshift?
Old Apr 17, 2006 | 11:59 PM
PANGES's Avatar
I did a search, but did'nt really know what to type in to search it, so I figure I should just ask. I thought I remembered reading a thread on this a while back, but could'nt dig it back up. Anways, i finally reached my 1000 miles yesterday and changed the oil today. After work today, I decided to give it a little pull from 2nd through 3rd... after I got near 7k rpm in 2nd, I shifted into 3rd, and right when I did, the I got a loud CLUNK from what sounded like the rear diff. Did I do something wrong or is there something about AWD that should be taken into account? (I came from a FWD then RWD car... this is my first AWD). Did I shift wrong or screw something up? I decided to stop messing around after that until I found out what happened. Any feedback would be cool. Thanks.
Old Apr 18, 2006 | 10:37 AM
SuperHatch's Avatar
Chances are it is the soft rear diff bushings flexing under torque. I've heard this a number of time from other new Evo owners.
Old Apr 18, 2006 | 10:40 AM
an0ther's Avatar
its fine, drive on, my viii did it and my ix does it. you will see the evo makes a lot of weird sounds but its really a tough car. I beat the **** out of my viii with 400 hp for 30k miles with no problems and im at 11k on my ix doing the same thing. I just dont launch much. The launch is what tears up our cars.
Old Apr 18, 2006 | 10:42 AM
KOEvo's Avatar
I ALWAYS listen for the clunk, without it i know i'm not shifting fast enough...
thetox's Avatar
happens in my IX if im really shifting hard but havent had any problems. Only happens every once in a while. I agree with SuperHatch....since hes the one who told me that in the first place lol
Old Apr 18, 2006 | 10:59 AM
Rnm's Avatar
Rnm
I use to get that noise when I would drop the clutch really fast between shifts, but now that I take my time with it, although still quick, I don't get that noise no more. Your letting out the clutch too fast in between shifts.
Old Apr 20, 2006 | 12:54 PM
Warrtalon's Avatar
It's the driveshaft hitting the carrier bearing near the rear diff.
Old Apr 30, 2006 | 06:04 PM
86gti's Avatar
it happens in my friends stock viii
also my other friend has a 240sx w/ sr20det w/ mods.. after he upgraded to a six puck from a solid disc clutch his rear end clunks as well
Old Jun 2, 2006 | 05:25 PM
WickedIXMR's Avatar
Is that bad for the car or what?
Old Jun 2, 2006 | 05:28 PM
Tsurugi-san's Avatar
What about stiffer diff bushings? Didn't someone mention a set of rear bushings that solved this issue?
Old Jun 2, 2006 | 05:47 PM
PANGES's Avatar
I've just been shifting a tiny bit slower and it's solved the problem. Shrugs. If you're at the drag stip then it might affect your time a tiny bit tho..
Old Jun 2, 2006 | 05:50 PM
Rez90's Avatar
when i first installed my ACT it felt like a sledgehammer hitting the rear diff between every hard shift.........loved it.....lol
Old Jun 13, 2006 | 11:35 AM
hondafan's Avatar
i'm pretty sure energy suspension(maybe prothane if not ES)makes polyurethane rear diff bushings for the evo to eliminate the movement that makes the "clunk".
Old Jun 13, 2006 | 02:24 PM
EVIL_EVO_VIII's Avatar
mine is so loud, when ppl ride in my car they think its gona break!
Old Jun 13, 2006 | 04:54 PM
Xfer's Avatar
Whew...I'm glad someone asked this. I thought maybe it was just my shifting. Being my first awd turbo and 6 speed.
