Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
launching
Old Feb 3, 2009 | 07:10 PM
  #31
ODUB's Avatar
Launching in an EVO is pretty damn simple.
i have an EVO IX MR, and from what i know the 08's have the same 5k two step on first right? if so, launching is very simple.
1. Put the car in first gear
2. Take the slack out of the clutch. let it out until you find the engagement point, and try to hold it as close to that as possible.
3. Press and hold the gas pedal to the floor. The car will rev to 5k and bounce off the 2 step.
4. Slip out the clutch until you feel it grab, then let go. The Slip/Dump method has always worked best for me.
5. Do not take your foot off of the gas until it's time to shift to second.
it's just that simple. that method netted me a 12.82 ET @ 107.41 in a basically stock EVO IX MR (HKS carbon ti catback, no tune, no other power adders). 1.86 60' because there was no way around the water box, and the track temp was 45*. spun tires through most of first.
just practice it, launching's not that hard. if you launch at anything lower than the 5k limit, or try to hold it at the limit without having the gas floored, you're going to bog.
just put the gas pedal to the floor and don't lift until you shift to second.
good luck.
Old Feb 3, 2009 | 08:58 PM
  #32
Evojj25's Avatar
That is weird b/c i don't have a problem launching my evo. i have grs and my 2 step kicks in at6200 rpm. so you shouldn't be having that problem.
Old Feb 4, 2009 | 04:40 PM
  #33
MATT@WORKS's Avatar
Talking
good luck.
Its really THAT easy? Does this mean there won't be anymore launch threads?!?!??!?
Old May 17, 2009 | 01:26 AM
  #34
ODUB's Avatar
someone should just make that a sticky and be done with it.
Old May 19, 2009 | 12:48 AM
  #35
MATT@WORKS's Avatar
Really? Should they? You think? 10,001 launch threads and not a single sticky. This should be "sticky" all over each poster's face.
Old May 28, 2009 | 08:46 PM
  #36
ice1874193's Avatar
Originally Posted by *constant_boost
he has an evo x...
im going to make videos on how to launch... onthe ix and x... to eliminate all of these ?'s
where is this mythical vid...
buckmarley
Feb 9, 2016 05:03 PM
moreno78065
Jun 25, 2015 09:30 AM
turbor850
Mitsubishi TC-SST Discussion
29
Dec 29, 2009 10:03 AM
617G
Sep 22, 2009 09:01 PM
Xcited
May 1, 2008 11:52 AM
