Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Double Clutching
Old Oct 5, 2003 | 08:43 AM
StreetRace609's Avatar
how is that a threaght ?
Old Oct 6, 2003 | 04:06 AM
neilschelly's Avatar
It's not a threat. That's what I said.
-N
Old Oct 6, 2003 | 05:34 AM
astondg's Avatar
Originally posted by neilscully
Rev-matching which is commonly combined with double-clutching (though it needn't be)
-N
True, but it kind of defeats the purpose, unless of course it is an up change.
If someone double clutches on a down change and doesn't rev match then it is worse than not double clutching at all because the slower change means engine looses more rpm that it has to gain in the next gear. Then they have a slow change that is harder on the gearbox. But if someone really wants to double clutch without rev matching, well it's their car.
On an up change it may not be necesary, depending on how quick they change (how many rpm are lost).
Aston
Old Oct 7, 2003 | 02:04 AM
Alan's Avatar
Re: Double Clutching
Originally posted by LancerBeast
Clutch in.
Shifter to neutral.
Clutch out.
Rev to appropriate RPM for syncros.
Clutch in.
Shifter into desired lower gear while rev matching.
Clutch out.
Do you really have to let the clutch out before reving the engine? becuase aren't you in neutral when the clutch is in?
Cheers
Old Oct 7, 2003 | 02:17 AM
liquidlancer's Avatar
well if you do it for speed matching input output shafts youd need to thave the clutch disengaged wile the tranny was in neautral to get the input shaft speed to match the output shaft speed and keep gears happy
but like everyone has been saying we have syncros just be nice to your lancer and it wont cost you tons of cash to get gears and syncros replaced!
Viegasjuice
Feb 21, 2014 01:31 AM
Lucas English
126
May 25, 2012 04:46 PM
tsitalon1
57
Mar 6, 2012 10:37 PM
1998YellowStang
18
Feb 21, 2007 06:52 AM
JRock
Dec 29, 2003 12:11 PM
