Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
burnout
Old Feb 16, 2004 | 11:01 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I don't think the RA has LSD either, does it? I didn't see it listed in the specs page. And yes, it is possible to do without LSD, but if you look at the tire mark you leave behind, you will most likely see only one track.
Old Feb 16, 2004 | 11:04 PM
SidewaysEvo's Avatar
yep. but that one side should have some nice smoke
Old Feb 16, 2004 | 11:30 PM
pearlwhiteoz's Avatar
i thought if you have LSD.. your carn will just launch instead of burning out.. cuz its limited slip.. so i guess your trannie to the wheel will just grab and go! correct me if im worng.
Old Feb 16, 2004 | 11:39 PM
Surfer_Sandman's Avatar
GO PEG LEG BURNOUTS!!! :-) oh and just pull the E-brake, really hard. or put blocks of wood in front of your rear tires. :-)
Old Feb 16, 2004 | 11:57 PM
yea it does help, but if u have enuff power u can spin both tires all day. When i had my acura cl type s (the six speed one) it had lsd and it spun tires all day
Old Mar 30, 2004 | 07:14 PM
typeR430's Avatar
i did it lots of times in my type R, rev it up a bit high, dump the clutch and immediately floor the gas as far as it goes, then you'll see the revs going up like hell, but you'll be sitting in the same spot when you get toward redline about to choke, let off the gas for a second and then mash it as far as it goes again, and just keep doing that until your tires pop
Old Apr 11, 2004 | 05:20 PM
Dem_z's Avatar
I dump the clutch at peak torque to do a burn out... In the lancer its like 4500 isn't it?
Ebrake of course... and w/o an LSD it burns out pretty nicely heh.
EclipseMblue
Northeast Region
15
Apr 21, 2007 07:41 PM
JohnnyBoy427
Lancer Troubleshooting
Mar 5, 2007 10:30 PM
loctfrank
Apr 1, 2005 03:43 PM
i_love_spool
Canadian Forum
Sep 30, 2003 07:38 PM
ogdelsol
Aug 26, 2003 12:06 AM
