DynoFlash [Visit Site]
Control Over Boost Seileniod
Old Mar 10, 2005 | 09:05 PM
  #61
antonio010's Avatar
Originally Posted by feldguy
Al, I figure, after is all said and done (mechanically) Im just gonna bring my car to you with a blank check and let you go silly. That is too much
Haha, reading through this thread makes me want to do the same!
Old Mar 14, 2005 | 07:43 PM
  #62
dru's Avatar
dru
I have had my car flashed by another tuner for 8 months now with no mbc and 19.5 psi solid no taper.
Old Mar 15, 2005 | 07:08 AM
  #63
TURBODAWG's Avatar
Question for Ben@Ecutek
Hello Ben,
So, the factory ECU has a built in closed loop boost controller scheme. What does it use for the feedback sensor. Does it use the MAP sensor for feeback??
Also, why does the load percentage go higher than 100%, is that due to the positive boost pressure?
Brian
"I have included the desired boost map and the turbo dynamics map.
The dynamics is a "boost error" map, so if the boost gets higher or lower
than the desired boost level it will add or remove WG duty accordingly.
We did not invent those; they have always been in the ECU...
I will also go back on the thread and explain more in details if there is a
demand.
Please do not hesitate to contact me if you require any further information
Regards
Ben Dagenais"
Old Mar 16, 2005 | 02:37 PM
  #64
voidhawk's Avatar
I think it'sclosed loop at partial throttle and open loop at WOT. Closed loop should use the O2 sensor in addition to the MAP sensor - but I'm only guessing on that one.
Old Mar 17, 2005 | 07:17 AM
  #65
dru's Avatar
dru
Originally Posted by TURBODAWG
Hello Ben,
Brian
demand.
Regards
Ben Dagenais"
thats a good question.
Old Mar 20, 2005 | 02:34 PM
  #66
Ben - EcuTeK's Avatar
Sorry for the late reply,
The ECU only use the MAF for Engine load and does not know what is the actual boost level.
Cheers,
Ben
EcuTeK North America
Old Mar 20, 2005 | 02:46 PM
  #67
DynoFlash's Avatar
The boost level is derived from a complex mathematical calculation based upon the engine rpms and load. There is a map sesnor but it does not perform that function.
Old Mar 23, 2005 | 05:17 PM
  #68
Aby@MIL.SPEC's Avatar
Good job for getting a handle on the "boost control" & not charging an arm & a leg for it Al.
Old Mar 23, 2005 | 05:54 PM
  #69
gsujeff55's Avatar
you guys don't wanna be able to control your boost?
you never put race gas in the car?
Old Mar 30, 2005 | 04:58 PM
  #70
05evoGSR's Avatar
Has this been tested this on a totally stock 05 and put it on a dyno? I would like to see what kind of gains this made with the reflash and the boost control for only $199.00.
Mike
Old Mar 31, 2005 | 10:28 AM
  #71
DynoFlash's Avatar
Mike
Here is a link to a thread with such a dyno sheet I just did last week
https://www.evolutionm.net/forums/sh...d.php?t=129907
RGV250
For Sale - Cars For Sale
Oct 16, 2014 10:50 AM
murkdevo
83
Oct 16, 2012 05:53 PM
Gruppe-S
346
Feb 10, 2010 10:20 AM
bluepeartype-s
Jul 3, 2007 06:44 PM
500whp.com
40
May 18, 2006 10:29 AM
