DynoFlash [Visit Site]
Case study # 31 - ATP Turbo Kit 3071 - Member Az3ar
Old Apr 12, 2005 | 11:55 AM
DynoFlash's Avatar
With this car - I wa snot trying to win any whp wars - just make a smooth curve and even out the power band
The tune that was in there was very good - just a bit of knock up top
I was able to get it spooling faster with a bit of tweaking
Main thing is that it is now running as stock on idle, driveability and start up which was the customer's main issues
Old Apr 12, 2005 | 11:57 AM
DynoFlash's Avatar
Originally Posted by SmoothOneBra
What did you do that slowed down his spool 600rpm?
Just two different dyno operators and one guy hits the button ealierthan the other
Old Apr 12, 2005 | 12:22 PM
teamdomokun's Avatar
Reaffirms my thoughts with aftermarket turbo upgrades.... you MUST have all supporting mods to make power from an aftermarket turbo. For example, cams are a must and I would even go with an AEM EMS if you wanted more power, but then you may have to sacrifice some driveability. Also, think about water injection. Just save a little more money and those numbers will come up.
Old Apr 12, 2005 | 12:35 PM
Al,
Was this car eqipped with any aftermarket intercooler or piping?
Old Apr 12, 2005 | 12:37 PM
Wrench's Avatar
Can you guess who hit the gas earlier? (hint: look at the start point for both curves......... )
And I suppose both pulls were under identical heat soak conditions.........
You go Al!
Techtom Rules
Old Apr 12, 2005 | 01:23 PM
NYREDEVO's Avatar
I don't know if it really matters, but from a cost standpoint it looks like he spent alot of money for not alot of results...340 is not really that impressive of a number for an aftermarket turbo, Im curious to see why he choose his route.
Old Apr 12, 2005 | 01:36 PM
DynoFlash's Avatar
True - its not much help without the cams and other usual mods
Old Apr 12, 2005 | 01:37 PM
jfh's Avatar
jfh
A- B comparision
Let the results speak for themselves
[/IMG]
Nice job cleaning up the top end. There are even a few additional pound feet of torque down low. Can't really quantify the improvements between the two in the range below 4750 RPMs due to the different start points for each run which makes the two graphs useless for comparison purposes below that point.
A true A-B comparison would have required that the start button be pushed at the same RPM point for both runs. The results would not have been visually as dramatic (see attachment), but at least the graphs would be a representative comparison throughout the power band.
No matter who is doing the tuning on this particular car, it's still struggling to make power considering the mods that have been installed.
Old Apr 12, 2005 | 01:48 PM
DynoFlash's Avatar
A true A-B comparison would have required that the start button be pushed at the same RMP point for both runs. The results would not have been visually as dramatic (see attachmnet), but at least the graphs would be a representative comparison throughout the power band.
The point was not to make more power or bash any tuner but rather to improve driveability and eliminate his cel code issues. To that extent the problem is fixed.
I was not expecting to make any more power than a great tuner like shiv - that is not realistic - obviously the set up was already almost at max whp. My goal was to smooth it out and fine tune it.
I will let the customer speak about how well I accomplished this
Old Apr 12, 2005 | 01:58 PM
GOKOU's Avatar
Nice job. Although street tuning is awesome it would be nice to have a chart like this for my car also . Wish I live closer to Pruven. Not sure if there's any pocket logger which shows something similar that is portable and can be use durng street tuning, before and after comparison.
Old Apr 12, 2005 | 02:29 PM
Wrench's Avatar
D'oh!
I hope you got his ok because if a tuner called out another like this with my results without clearing it first, I woudn't be so happy.....
Techtom Rules
Old Apr 12, 2005 | 02:52 PM
mndeerslayer's Avatar
Originally Posted by Wrench
D'oh!
Techtom Rules
Please, PLEASE go back to your Vishnu forum. I'm sick of reading this BS. You have your own thread on this topic, use it.
Old Apr 12, 2005 | 03:24 PM
Turbo13's Avatar
Hey AL what could you expect out of this kind of setup with all the supporting mods? I have been curious about this turbo setup. thanks
statix's Avatar
Hey Al, how much boost and how do you compare this turbo to a tme 10.5....
Old Apr 12, 2005 | 04:08 PM
Wrench's Avatar
Yeah, it's closed
This thread is way more fun anyway.
If you don't take us too seriously, we won't either.
Back to my cave now...........
Techtom Rules
