DynoFlash [Visit Site]
alcohol injection?
Old May 2, 2005 | 11:18 PM
troutfishin02's Avatar
alcohol injection?
methanol? ethanol? It definitely sounds like a great bang-for-the-buck mod, but what the hell do you put in the tank, and how much does it cost? Do you get it from auto-zone, or the ABC store?
I've searched and searched, but all I can find is debates about HOW it works, not what you're supposed to use.
Old May 3, 2005 | 12:07 AM
DynoFlash's Avatar
You can use rubbing alcohol, denatured alcohol from home depot, methanol or even winsheild washer fluid - main trick - use the same stuff you get tuned on all the time as the tune varies with the exact fuel you inject
Old May 3, 2005 | 06:24 AM
ct9a gsr's Avatar
It seems methanol will give you the most power out of any other substance, however, finding 100% methanol may be difficult. My local shop sells it by the gallon for about $4.00 or so per gallon.
Not to be off-topic or hijack the thread, but please respond to your PMs Al concerning the alky kit I purchased last Tuesday.
Old May 3, 2005 | 08:59 AM
Yaroslav's Avatar
Check Methanol in Drugstore, i biught it there
Old Oct 13, 2005 | 08:27 PM
yesevo's Avatar
for real?
Old Oct 13, 2005 | 08:34 PM
Type-VIII's Avatar
I just saw this today. Link
Old Oct 13, 2005 | 08:35 PM
evolgrl's Avatar
Can anyone please tell me what you need to run this set up i.e. fuel rail injocters. p.s. sos.....
Old Oct 13, 2005 | 08:44 PM
Type-VIII's Avatar
Just the kit and tune..Kit
Old Oct 13, 2005 | 08:48 PM
evolgrl's Avatar
Thank you no long problems.
Old Oct 13, 2005 | 08:58 PM
evoego's Avatar
Registered User
dang dude..I will sell it to you for half that. its 3 a gallon here. i race go karts so I pick up extra when I go to the track
Old Oct 13, 2005 | 11:01 PM
C6C6CH3vo's Avatar
I don't have the kit but I do know a little about organic solvents
In order of ideal heat of vaporization, vapor pressure, and higher flash point it is this order: Methanol>Ethanol>Isopropanol.
So I would guess methanol is best i.e., coolest evaporation and highest knock suppression, however the cheapest to obtain would Ethanol (denatured - not pure but close) $9/gal at Lowes. Isopropyl is found anywhere cheap for $1.79/32oz but is only 70% and some places 90%
  1. Methanol [wood alcohol, methyl alcohol, Heet (at auto stores), Conc. window cleaner (%50)]
  2. Ethanol (Denatured, EtOH, Ethyl alcohol, everclear, Grain) - Denatured is the only economical feasable one.
  3. Isopropanol (rubbing alcohol - 70%, isopropyl alcohol, 2-propanol, Isoheet (advance auto)
Warning: methanol can kill you, so if you have kids don't leave it laying around, and use gloves. It is also the least polar of the 3 alcohols, so 100% might be tough on the plastic fittings, I don't know, concentrated window cleaner (the right one) at 50% is prob OK.
If I had an alcohol kit, I would buy me a 50 gal drum of 100% Isopropanol from a chemical supply store for about $200 and get it tuned for that stuff. It would be H2O free, pure, the easiest on the kit, the safest, and won't ruin your paint finish. But only do this if your a law abiding citizen for a purchace like that may put you under DEA survailence.
Note: Denatured alcohol is poisonous too, it's comprised mostly of ethyl alcohol but has some methanol and other crap the wakko left govt put in there for liquor tax reasons and to deter consumption.
Old Oct 16, 2005 | 04:26 PM
yesevo's Avatar
windshield washer contains 50% methanol in it?????????
Old Oct 17, 2005 | 04:50 AM
C6C6CH3vo's Avatar
washer fluids has about 5%
I said Concentrated washer fluid that comes in 16oz containers for $2 and you have to dilute yourself is 50% methyl alcohol
Old Oct 17, 2005 | 07:43 AM
Ev0ikon's Avatar
Pure Methanol is about $3+tax per gallon at my local race shop.
Old Oct 17, 2005 | 08:34 AM
DynoFlash's Avatar
racing methanol is the best and cheapest
