DynoFlash [Visit Site]
WI and Cams
Old May 9, 2005 | 06:19 PM
honki24's Avatar
Question WI and Cams
Hey Al, hope I can reach you here... been unsuccessful via phone, email, and PM. Ok, so I just put in my WI kit, initiating @ an incredibly low 4 psi w/ no bog, w/ a 3.9gal/hr tip... meaning w/ my stock injectors I'm running approx. 13% water/fuel. I have read of others on here who use WI and lean out to 11.5 and add timing, as I can tell that just cranking up the boost won't be as beneficial as having it leaned out a little and turning up the boost some.
Question: with the WI do you have a mail in flash setup predetermined? or do I have to specify what I'd like my parameters to be? Tell me what you can do to make this good mod a great one bro.
Background:
{3" TB w/ test pipe, SSQ, cone intake, hallman mbc, 93 oct}--all been flashed for
{WI, 264/264 (hopefully GSC)}--want a reflash for (I'd like to run ~23psi on stock
turbo w/ NO knock)
so, specifically, what would a reflash for these mods include?
reason I ask is because I don't have a piggyback, I borrowed a friend's logger, and w/ WI @ WOT I was getting down to around 6-8 degrees advance in timing. @ what timing would you think I'm starting to see knock?
Summary: how would YOU re-flash me for WI and cams (please separate by WI/cams)
what timing advance should I see @ wot?
**I know this post must be annoying to you as it is long and such... but I would really appreciate a thourough answer, I enjoy your flash and hope to continue to support a great product.
Old May 13, 2005 | 11:27 AM
honki24's Avatar
check it out... 47 views and 0 replies... Al, you're so hard to get in touch with AAAAAHHH!!!
Old May 14, 2005 | 06:00 PM
honki24's Avatar
85 views and 0 replies... I'm gettin nothin here Al!!
tim85851
Aug 20, 2011 10:00 AM
Vigman
16
Jun 16, 2010 12:54 AM
nothere
Sep 18, 2009 08:48 PM
honki24
Jun 20, 2008 06:04 AM
nothere
Jun 20, 2004 09:32 AM
