DynoFlash [Visit Site]
O2 Simulator...
Old May 26, 2005 | 07:35 PM
Cosner's Avatar
O2 Simulator...
Will an O2 simulator that alters the signal for check engine light interfere with anything the flash does to the ECU? I have a test pipe that's giving me the cel and want to make it go away. Any advice?
Old May 26, 2005 | 07:40 PM
SMrider102's Avatar
nope, i have a mail-in flash and a an o2 simulator and have had no problems whatsoever
Old May 26, 2005 | 07:44 PM
SlowCar's Avatar
go get yourself a pair of 18mm spark plug anti-foul, bore one of them to 1/2"ID. dont mess around with that O2 simulator.......some dont work...
Old May 26, 2005 | 08:29 PM
Cosner's Avatar
[QUOTE=SlowCar]go get yourself a pair of 18mm spark plug anti-foul, bore one of them to 1/2"ID.
What does that mean?
Old May 26, 2005 | 08:33 PM
an0ther's Avatar
when you buy them, you'll understand fix works great, no cel in 8 months since I did it. It only cost $5 too, alot cheaper than simulator
Old May 26, 2005 | 08:36 PM
MYEVOVIII's Avatar
Search under mechanical o2 fix. Will cost you less than $5 and will get rid of your check engine light
Old May 26, 2005 | 08:38 PM
MYEVOVIII's Avatar
It works by moving the rear o2 sensor out of the stream just enough to give a different signal than what the front 02 sensor is reading. This tricks the ECU by thinking the Cat is working by a change in the reading of the exhaust gases. The rear o2 sensor is just there to make sure the Cat is working basically.
turbotaloon95
Aug 9, 2016 07:51 AM
boy36
14
Dec 24, 2009 09:57 AM
EricR
Apr 25, 2006 02:43 PM
XRS-Lift
12
Apr 19, 2004 03:01 PM
SilverEvo8owner
Oct 6, 2003 06:22 PM
