WALBRO fuel pumps REQUIRED on all MBC and EBC equiped cars
Guys, I am instituting a REQUIREMENT that all MAIN IN reflash orders must have a upgraded Walbro fuel pump if you are running any form of boost control - MBC or EBC on any 2003 - 2005 Evo 8 (Evo IX NOT included)
Custom tuned cars will still be accepted on the stock fuel pump - without cams as I can then monitor the situation more closely - however it is still STRONGLY suggested to have a walbro pump in all cases
If Walbro fuel pump is not listed in the mods I won't install a reflash unless you agree to purchase a walbro fuel pump - source Buschur Racing 440-839-1900
In the past I have suggested Walbro fuel pumps strongly
90% of my customers have followed my suggestion
For those 10% who dont want to spend the $90 or so to get the pump to help make a more stable and reliable main in flash, I am sorry I cant help you
Also * * * ARP head studs and ROD BOLTS are also suggested
Finally, I am lowering the MAX rev limit to 7700 - from 7800 on all mail in flashes - stock is 7606
Thanks
Thanks
Originally Posted by race17k
have you had alot of problems lately al or just being cautious?
I guess I was one of the 10% you were refering to. Just to give you guys a clue, I had Al custom tuning mycar the first time under the following conditions:
No upgraded fuel pump
No head studs
MBC
CAMS
and the rev limiter to 8000rpm
As you can see, I have been running my car under the opposite conditions that he ideally wants/prefer. That gives you an idea of how safe his tunes are.
But lets get to the point, he improved his tuning methods to a much safer level and I think we all should consider that, I will be the first one to change my tune to his new sugested seting. My car has been runing flawlesly but if he says he suggest upgrading the listed mods then that is what need to be done guys!!
Thanks for the update Al.
Carlos
Originally Posted by fromWRXtoEVO
Al,
I guess I was one of the 10% you were refering to. Just to give you guys a clue, I had Al custom tuning mycar for the first time under the following conditions:
No head studs
MBC
CAMS
Carlos
No head studs
MBC
CAMS
Carlos
Originally Posted by Turbolover
I think all flashes should require a fuel pump upgrade.
Originally Posted by John4321
will the walbro fuel pumps work with the Evo IX?
The IX pump is slightly stronger than the 8 one but the walbro is the best bet as with the IX the pump runs out of steam when the car starts making power as the IX's do !
Originally Posted by sirploppy
Al, would you go on to recommend all flash customers upgrade the fuel pump even on stack boost control? I plan on purchasing a flash pretty soon but I plan on keeping the cars original boost control system intact. (solinoid, pill, etc...)
Originally Posted by smokedmustang
Good points Al, take a Blood Pressure pill, and dont let anyone get under your skin.
I am just not feeling trying to help out someone who is trying to cut corners with their car and save a few bucks only to find other tuners nit picking my work
I rather just do it once and do it right
When you raise the boost you really need a fuel pump
I get much better results on cars that have fuel pumps and it removes an unknown variable which can result in a disapointing result for the customer and myself
if it means a few less sales at years end, I can deal with that
I only want the best possible product
