engine wear with e85?
Old Jul 3, 2009 | 04:01 PM
lan_evo_mr9's Avatar
There's a good link to some engine oil analysis in one of the threads talking about oil and E85. That thread has a link to another evo forum where a guy did a bunch of oil analysis with different kinds of oil. It's very informative and gives you an idea of what to run. After reading the thread, you will find out that engine wear is perfectly fine after 5K of abuse. No worries if using the right oil. I'm running two catch cans on top of using some good oil, and the catch cans capture all the condensation/oil mix.
when I was running pump gas only, straight oil would come out of the cans. Now when running E85 for a long period, without going back to gas (few months), the "oil" draining from the catch cans looks like coffee colored mud. Highly reccommend catch cans if running high boost and sustained E85 use. I have absolutely no oil in any IC pipes, manifold, etc.
I personally am using Castrol Syntec 5w-40.. It's free at work and had a good oil analysis.
Old Jul 3, 2009 | 05:14 PM
skiracer's Avatar
If you're running E85 or any race gas at 28PSI you will have more wear and tear versus running 22PSI on 91 octane.... That's a no brainer...
Old Jul 4, 2009 | 07:15 PM
You can limit the wear by using the correct oil on E85. Of course there will be more stress when upping the power/boost- just like any car. But more stress does not neccessaryily have to equal more wear. Stress and wear are two different categories.
Old Jul 4, 2009 | 07:58 PM
mrfred's Avatar
Originally Posted by lan_evo_mr9
... Now when running E85 for a long period, without going back to gas (few months), the "oil" draining from the catch cans looks like coffee colored mud. ...
I get the same thing in the catch can coming off the valve cover.
Old Jul 4, 2009 | 08:06 PM
2LOFD3ATH's Avatar
Thats a retarded amount of water, hell, if it was that much It would run purely on water as the water is heavier than the e85 and won't stay blended as it will all sink to the bottom of the tank, deff not a worry.
And those talking of oil analysis, it is deff a worth while investment every once in a while.
Old Sep 25, 2023 | 05:26 PM
conv88gtstang's Avatar
Originally Posted by evilution310
"For ethanol contaminated with larger amounts of water (i.e., approximately 11% water, 89% ethanol, equivalent to 178 proof ethanol), considerable engine wear will occur, especially during times while the engine is heating up to normal operating temperatures. For example, just after starting the engine, low temperature partial combustion of the water-contaminated ethanol mixture takes place and causes engine wear. This wear, caused by water-contaminated E85, is the result of the combustion process of ethanol, water, and gasoline producing considerable amounts of formic acid (HCOOH, also known as methanoic acid and sometimes written as CH2O2). In addition to the production of formic acid occurring for water-contaminated E85, smaller amounts of acetaldehyde (CH3CHO) and acetic acid (C2H4O2) are also formed for water-contaminated ethanol combustion. Of these partial combustion products, formic acid is responsible for the majority of the rapid increase in engine wear."
is this a concern on normal warm up? or is there only a worry if the e85 gets contaminated?
I have a friend with a 2010 Shelby GT500, it runs E85 at about 900hp. He filled the tank with E85 from a station that had a crack in the storage tank and the fuel was flooded with water. We have flushed the fuel system all the way thru to the fuel injectors. The car ran fine for a short period of time afterwards. Now the car won't start. I've pulled the spark plugs and conducted a compression test, of eight cylinders only one is at 150psi while the others range between zero and 30psi. is it possible to have wiped the cylinder walls completely smooth or have damaged the rings to such a point with seriously contaminated E85.
Any insight would be greatly appreciated.
Thank you,
James
edsct9a
19
Aug 9, 2016 05:48 PM
Acree
Jun 23, 2011 02:08 PM
trinydex
26
Oct 13, 2007 01:16 PM
Kc2Buk
61
May 5, 2006 11:39 AM
EVO316
South Region
34
Apr 20, 2006 01:07 AM
