Please post your E85 stock turbo IDC%
Old Jun 9, 2008 | 06:48 PM
mplspilot's Avatar
Stock 9.8 VIII turbo with 1000cc and one Walbro 255
Log 1:
7000 rpm
21.3 psi
10.9 AFR (gas configured wideband)
87% IDC
Log2:
7125 rpm
20.1 psi
11.2 AFR (gas configured wideband)
82% IDC
I don't see how the max PSI matters when it comes to IDC's, but since you asked it was 27psi in log 1 and 26psi in log 2. Logged with JDM MAP.
Old Jun 13, 2008 | 04:08 PM
mrfred's Avatar
First tank of E85. Probably more like E75. No tuning except to dial in the injector scaling. Running FIC 1050s scaled at 696 cc/min. I'm finding that FIC 1050s are pretty much exactly 2x the flow capacity of stock injectors.
7000 rpm
20.0 psi
11.0 afr (gas configured)
70% IDC
With more tuning, I suppose I'll hit about 80% IDC.
Pump gas values are:
7000 rpm
20.0 psi
11.0 afr
47% IDC
Old Jun 14, 2008 | 10:14 PM
fre's Avatar
fre
I think another big factor is fuel rail, fuel lines and fuel pumps being used. By simply switching from a inline walbro 392 to a bosch 044 my A/F ratio went from 12.5:1 to 11.5:1 and my duty cycles dropped from 98% to 94%. So it runs richer and runs less duty cycle. Now that I have it dialed in at 11.7-11.8ish I am down to 92% duty cycle.
Old Jun 14, 2008 | 10:33 PM
mrfred's Avatar
The more powerful pump is pushing up the fuel pressure.
Old Jun 15, 2008 | 06:59 PM
fre's Avatar
fre
The base fuel pressure stayed the exact same at 50psi. I checked it and didn't touch the regulator.
On the top I believe it is simply keeping up now, where the walbro was not keeping the 1:1 ratio as boost got really high. The 392 is nowhere near as good as the bosch in the 80-90psi range.
Old Jun 15, 2008 | 08:32 PM
mrfred's Avatar
ok, I checked, and you're not on the stock turbo, so not surprising that a more fuel pumping power made a difference. Stock turbo setups should be fine with a Walbro. Max boost I figure I'll see at 7000 rpm is 22 psi which gives a fuel pressure of 65 psi (or maybe less since the Evo base pressure is closer to 40 psi). A Walbro can flow 4 liters/min at 65 psi. If my FIC 1050s are at 85% IDC, that's 3.4 liters/min. More realistic is probably about 80% IDC since which gives 3.2 liters/min. So there's still a reasonable (but not fantastic) amount of additional fuel flow available with stock turbo setups. My concern with a stock turbo is not for the Walbro but the fuel rail.
Old Oct 14, 2008 | 07:46 PM
eitan's Avatar
Stock VIII turbo, FIC 950s, 25 falling to 22-23, 62% max IDC.
hollywood_X
88
Aug 31, 2014 10:42 AM
3gEclipseTurbo
May 22, 2010 12:00 PM
purekoryo
11
Apr 7, 2009 02:57 PM
cky_bam_marg
Oct 5, 2008 05:46 AM
