Made switch to e85 today
Old Jun 18, 2008 | 09:12 PM
  #31
mrfred's Avatar
Originally Posted by oldevodude
PS I'm still wanting to try those SARD injectors as they might make the idle smoother. It's not bad mind you,but it's not stock either
My FIC 1050s give a stock quality idle with E85. Idle is a bit choppier than stock on pump gas. I just took a look at the SARDs. Their website says that fuel rail mods are needed to user their injectors. Not sure how true that is. They appear to be using Denso injectors. No mention of any custom design or modification.
Old Jun 19, 2008 | 09:09 AM
  #32
oldevodude's Avatar
Here is a link to their injectors and part numbers. I wil ltry to call them today. You will note they list 1000 cc low impedance in both 1 and 2 hole design.
http://www.sardracing.com/products/Injectors.htm
Old Jun 19, 2008 | 09:16 AM
  #33
skiracer's Avatar
I'm using RC Engineering 1000cc injectors and they idle just fine on 91 octane or E85. The only hitch i have is that the engine slightly hesitates at cold startup.
Old Jun 20, 2008 | 10:49 PM
  #34
nj1266's Avatar
If you want to make your idle smoother, then run more timing in the top left hand corner of your timing map. Try 10-12*. This will make it smoother. also try and increase your idle speed by about 25-50 rpms. That should help. I am running RC 1000 cc injectors and more timing at idle smooth the idle nicely.
Old Jul 2, 2008 | 12:38 AM
  #35
oldevodude's Avatar
Sorry it's late but thanks I will try more timing as currently it is 6-8 range only at idle
Old Jul 2, 2008 | 07:04 AM
  #36
mrfred's Avatar
I'm running 14 deg at idle.
Old Jul 2, 2008 | 09:26 AM
  #37
Jim in Tucson's Avatar
I think that is pretty much normal, due to the less explosive nature of E85.
I wonder if one of those plug-in ignition amplifier modules would help any? Or perhaps a coil-on-plug set-up?
Has anyone running E85 done any ignition upgrades?
Old Jul 2, 2008 | 09:37 AM
  #38
mrfred's Avatar
Its the lack of atomization at cooler temps. Would be interesting to compare the factory ignition to an aftermarket. Seems that the only aftermarket ignition worth buying is $1000 though.
Old Jul 2, 2008 | 11:05 AM
  #39
skiracer's Avatar
Taking 1-2 tries to startup the car is just a minor annoyance. I don't think its worth the $$ to spend on any sort of ignition upgrade, unless you're having mis-firing issues.
Old Jul 2, 2008 | 10:30 PM
  #40
oldevodude's Avatar
When doing research a while back it is noteworthy that a lot of the aftermarket e85 conversions have temp sensors and when cold they squirt more fuel to aid in cold starts this is not a ignition issue based on that.
I upped timing a couple degrees but need to do more I went plus 2 which put me to 8 i believe
Thanks for the replies
Old Jul 6, 2008 | 10:09 AM
  #41
oldevodude's Avatar
Here are the 2 hole injectors I'm such an airhead.......
http://www.powerenterpriseusa.net/pr...ctor/index.htm
The design looks promising it is too bad these are so expensive. Need fuel rail with these also I believe.
I called SARD USA and they are supposed to call Japan and find out about EVO specific big injectors but I have not heard back from them
goofygrin
86
Aug 6, 2013 08:09 AM
car_nut15
Toronto Lancer Club
Oct 22, 2011 08:08 AM
evowner17
Dec 23, 2010 09:56 PM
delkat
Feb 17, 2010 10:16 PM
Kc2Buk
61
May 5, 2006 11:39 AM
