graph of run today on e85
Old Jun 16, 2008 | 11:32 PM
oldevodude's Avatar
I posted this over on socalevo but figured i would put it up here as well
Here is a quick run on e85 with 91 timing and fueling maps and simply cranking up the ecu based boost !!
Old Jun 17, 2008 | 04:58 PM
mrfred's Avatar
And you said in another post that there was no knock?
Old Jun 17, 2008 | 04:59 PM
YzBrad99's Avatar
What kinda graph is this? Dollar Generals Dyno?
Old Jun 17, 2008 | 05:14 PM
taenaive's Avatar
Old Jun 17, 2008 | 05:23 PM
mrfred's Avatar
Says in the upper right that is 2-byte load and boost.
Old Jun 17, 2008 | 05:54 PM
oldevodude's Avatar
If you wanna pay for a dyno run I'll get gladly go get one and post that instead. That would make it a general your dollar dyno run and graph.
What kinda graph does it look like to you? To me it illustrates over 25 psi boost and around 300 load.
Old Jun 17, 2008 | 06:08 PM
oldevodude's Avatar
Several runs no knock but today it was hot outside low 90's me thinks and....
Miscellaneous 1 count, spread out between 4500 and 5500 270-80 load range (5 total over 2 runs).
If I am to try more boost I will pull timing in these areas first. My objective was for me to slowly up the boost till the onset of knock and I am glad at least someone else got something positive out of it.
Old Jun 17, 2008 | 10:11 PM
YzBrad99's Avatar
I'll pay for it the day you learn how to take a joke
Old Jun 18, 2008 | 12:44 AM
oldevodude's Avatar
I did the comical end of it and I still want you to pay for my next run hey it was worth a try.....
Old Jun 18, 2008 | 04:03 PM
PeteyTurbo's Avatar
Looks like a poloroid taken of the actual lapstop screen.....Then scanned!!!
Old Jun 20, 2008 | 10:54 PM
nj1266's Avatar
Oldevodude, you can e-mail me your log and I will run it in DLL and post the dyno for you. Also e-mail me the zip code and date/time and gas in the car.
Anyone know how much a gallon of E85 weighs?
Old Jun 21, 2008 | 06:23 AM
mrfred's Avatar
Almost the same as gasoline. E85 is only a few ounces heavier than gasoline.
Old Jun 21, 2008 | 09:31 AM
skiracer's Avatar
lol
razorlab
E85 / Ethanol
115
Sep 14, 2019 12:28 PM
dcdirtrider
E85 / Ethanol
19
May 25, 2016 07:39 AM
Z2EVO
South Region
Oct 5, 2014 11:17 AM
mx5tc
E85 / Ethanol
May 9, 2009 12:39 PM
