Dual fuel tanks
Old Jun 24, 2008 | 11:36 AM
RyeLou's Avatar
Dual fuel tanks
Is there a way to have a switch to go between the stock fuel tank and a fuel cell?
There is obviously a bit of a concern with mixing regular gas and E85. Depending on how much you mix, you could potentially throw off the octane rating and burn characteristics quite a bit. If there was a way to have a fuel cell in the trunk and have a switch to have the fuel pulled from there you could change the tune back and forth very easily without worrying about the fuels mixing. Obviously you would need two tunes and the capability to switch back and forth, but that's already readily available.
Old Jun 24, 2008 | 11:39 AM
2muchboost's Avatar
ive seen it done B4..
If you have the $$$ anything is possible.
but it can be done.. not out of the question at all.
Old Jun 24, 2008 | 11:42 AM
2muchboost's Avatar
talk to Vishnu performance. I think ive seen them do it..
Old Jun 24, 2008 | 11:49 AM
mitdrx's Avatar
You set up the fuel cell like normal. And then you wire the fuel pumps to toggle switches and give them power individualy.
Old Jun 24, 2008 | 05:25 PM
skiracer's Avatar
Just drive about 10-20 miles after your fuel light comes on and put in your desired fuel....Sounds a bit easier...
Old Jun 26, 2008 | 04:58 AM
tephra's Avatar
**** me thats a big signature...
yeah dual fuel is hard to do, but i guess the 'cheap' option is just have a 10L jerry can in the boot - fill it with moonshine :P
Old Jun 26, 2008 | 09:13 AM
EvoKnievo's Avatar
you could get the AMS VSR intake manifold with the dual fuel rails, have one hooked up to the stock tank and a extra set for your fuel cell. you can add a second row of injectors to most manifolds. this why you would not contaminate the 2 fuels by blending them in the same lines....
Old Jun 26, 2008 | 09:24 AM
tabio42's Avatar
If you can switch between the two pumps in the two tanks then that is half the battle. You also need to be able to switch the fuel return lines so you don't start mixing fuel.
jordo
Oct 11, 2012 02:51 PM
neonglh
Sep 25, 2010 07:06 AM
David Buschur
Jun 23, 2009 12:56 PM
David Buschur
61
Jul 28, 2008 07:20 PM
TrinaBabe
27
Oct 5, 2006 01:09 PM
