Anyone switch to E-85
I am currently running 91 with 50 meth/50 H2O. In other week upgrading to and Evo Green, larger injectors, ECU alt map switching to use E85 or 91.
Does anyone have any experience with running meth 50/50 with E85... it would be easier for me just to continue to spray meth when running 91 or E85. But, is there any advantage to not running meth/h2o with E85? Seems to me not much if any advantage to spraying the meth, but the h2o would help to control knock with E85.
Thanks...
Thanks...
http://i335.photobucket.com/albums/m...1methvsE85.jpg
Gained 51 max hp and 16 ft-lbs of torque on E85 vs 91+50% meth. Both tunes were done consecutively on the same dyno at Harman Motive in Torrance, CA. Huge thumbs up to Dan H and Scott B! The quality of their work and tuning is top notch. Quality of work and customer service is the best I've had in SoCal.
E85 - 376 hp & 357 ft-lbs tq
91+ 50% meth - 320 hp & 341 ft-lbs tq
For reference: was told that the new GTR did 405 hp on the same dyno
I was amazed how smooth the E85's hp and torque curves... The car is my DD and a blast for street driving.
My mods include:
FP Green ported turbo w/FP actuator
RC1000 injectors
FULL RACE exhaust manifold (tubular)
HKS 272 MIVEC cams
65mm Mil Spec TB (ported)
Sparco Intercooler
Springs & Retainers
Horsepower Freaks LICP
UICP
AEM meth kit
ECU load boost control
HKS DLI II
TiTek O2 housing
Walbro Fuel Pump
AMS small battery kit
K&N Intake
Full exhaust w/test pipe
HKS Ti Carbon muffler
Buddy Club grounding kit
DEFI gauges (EGT, Boost, Oil Pressure)
Labonte flow gauge (for meth)
AEM A/F gauge
JDP map sensor (for logging)
Stock ECU (flash w/ alternative map switching functionality)
My mods include:
RC1000 injectors
HKS 272 MIVEC cams
Sparco Intercooler
Springs & Retainers
UICP
AEM meth kit
HKS DLI II
TiTek O2 housing
Walbro Fuel Pump
K&N Intake
AEM A/F gauge
Do it, E85 is the bomb. I have run 34psi on it accidentally (3500ft elevation drop) and got no knock. I ran 32psi at the track on E85 when I got the time in my signature (360 treadwear ftl). I run 30-31psi when I drive it on the street and never see any knock.
You will need a dual fuel pump setup of some kind and at least some 1000cc injectors though. I have to say, I have tried 2 walbro 392 inlines and now have the Bosche 044. Just save yourself the hassle and get the Bosche, unless you do a dual in tank setup.
I remember when I was running a walbro 392 inline and it died and I was left with only the in tank and I was running way lean. I think I was still 45psi base back then and running around 30psi of boost. If you are on a smaller turbo I could certainly see 28psi with only an in tank, because it flows less. You could also be running quite a bit less timing than I do.
SmurfZilla
E85 / Ethanol
16
May 28, 2009 07:39 AM
