Tips on a AMS 30r on E-85?
Old Nov 12, 2008 | 11:30 PM
NomadMR's Avatar
just got the pte 1200's but the weather is sucky and i cant get to chicago safely in dry weather up hear for my tune so ill just have to wait for winter to be over and ill do my tune and track for those numbers.
Old Nov 13, 2008 | 07:04 AM
tnt1106's Avatar
Here are my e85 tune numbers. This is conservative I am sure I could run more timing. On stock clutch so I think I am hapy with where I am at. Just clean up the tune then done.
This is at 25psi:
And the log for that pull:
82% IDC 1050 fic and 1 walbro 255.
Old Nov 13, 2008 | 08:36 AM
kcevo's Avatar
For reference I did an AMS 3076r kit on a stock 2.0 with BC 272 cams Full blown dual pump setup and 1200cc injectors on the stock ecu. This car on E85 was making 484whp with 88%IDC's @ 32.5psi of boost.
Every E85 car I have done with a single fuel pump, from 1000cc to 1600cc injectors on the setup, will run out of fuel ~450whp.
Old Nov 13, 2008 | 09:38 AM
mplspilot's Avatar
Your IDC's are low because you run 12.7 AFR at 8k. Not everyone is gonna do that. it's a bit unsafe to say the least if you ask me. Especially on winter blend.
Old Nov 13, 2008 | 10:08 AM
gsxwingz's Avatar
^^^ agree. Those are too lean for E85.
What I have found from tuning EVO's and Suby on E85 when on the dyno is it will make more power 11.2-11.8 afr's rather than 12's:1.
Old Nov 13, 2008 | 11:24 AM
FastFreddy's Avatar
I did 363hp and 359trq to the wheels on a DynoJet. Tune done by Phuong(WingzPerformance) on E85.
Mods:
Blitz Drop in Filter
Hallman BC
Works o2
Works Turboback
XS engineering 272cams
HKS 1000cc inj.
Walbro 255
Best time at the trak sofar 12.4@111mph.
Old Nov 13, 2008 | 11:37 AM
tnt1106's Avatar
yes its a bit lean, however at 11.5 (log from 2 days ago) its still at 83% idc.
Old Nov 13, 2008 | 10:18 PM
ineedspots's Avatar
very interested...
im thinking of making the switch to E-85
on my current set up i made 385hp/331tq on 100oct
-atp 3076
-hks 272s
-turboxs intercooler
-AEM intake
-perrin boost tube uicp (came on the car looking to get rid of it)
-chis at AMS tune @ 26psi
im lookin for a bit more and hope e-85 will help with that
plus im payin 6.50/gal for gas right now and im daily driving
on 100 (dumb i know but whatev) so this will be a lot cheaper
Old Nov 14, 2008 | 01:20 PM
NomadMR's Avatar
yeah chris did my tune also but for pump on a evo 9 and set mine at 22psi am at 387whp i have a ams 3076,kelfords 272, springs retainers, injectors , pump and all other supporting mods. so i want this e85 as well to get some higher power.
Old Nov 14, 2008 | 08:41 PM
oldevodude's Avatar
Originally Posted by ineedspots
very interested...
-atp 3076
-hks 272s
-AEM intake
do you have any dyno graphs of your atp kit? I wanted to see the boost plot but regular hp/torque would be cool. I'm just curious how it spools and what rpm peak torque and hp are based off your current tune
Thanks
Thanks
Old Nov 14, 2008 | 09:26 PM
ineedspots's Avatar
i just have a regular hp/tq chart
im not sure how it will turn out
since i scanned it so heres a link to
the chart also....
http://img61.imageshack.us/my.php?im...forevomzl0.jpg
Old Nov 18, 2008 | 08:19 AM
gsxwingz's Avatar
E85 power and its beauty. Here's FastFreddy's dyno and log charts. Mind you this is stock evo8 turbo with smaller hotside. Pull after pull, it does not knock even 26-27 PSI on top of 8-10 at peak boost ramping to 18-19 degrees at redline. Simple mods tbe, injectors, and cams.
[IMG][/IMG]
patricknogaj
Jan 21, 2017 06:04 PM
Jmills
34
Dec 22, 2016 06:22 PM
ohYouEvo
Evo X Dyno Results
17
Sep 10, 2015 07:11 AM
nateevo8
Feb 18, 2015 04:08 PM
ReignMan24
May 30, 2012 01:58 PM
