White Lightning Flex Fuel Kit
Old Mar 12, 2009 | 10:32 AM
4-BNGR's Avatar
Has anyone used this product? Thanks in advance. http://www.mye85kit.com/the_e85_kits/index-14.html
Old Mar 12, 2009 | 10:31 PM
Jim in Tucson's Avatar
My hunch is that these types of devices simply intercept the injector signal and add 30% to the IDC. Prolly works just fine on the average mom and pop car that has sufficient fuel trim built into the ECU for any fine tuning needed.
However, I doubt this type of device has the level of sophistication that we EVO owners demand.
IMO, if you wish to go with E-85, get a real E-85 tune. We are so fortunate that we can actually do this. For a lot of car owners their only option is MyE85kit dot com.
Old Mar 13, 2009 | 02:04 PM
4-BNGR's Avatar
1) Is it giving 30% more fuel? (would this max out the stock evo injectors) or 2) simply increasing the amount of injector "on time" (thereby not maxing out the capability of the stock injector, but just sending a second smaller pulse)?
I think it's the latter? Anyone?
Old Mar 13, 2009 | 03:24 PM
recompile's Avatar
It doesn't make sense for us, when we have a free program (EcuFlash) that can adjust the injector scaling, and 3rd party ROMs (Tephra) that allow map switching.
This product works the only way physically possible, which is just increase injector open time, ie, higher duty cycle. If you're already over 70% duty cycle on gasoline, you can't use E85 without upgrading your injectors, not even with this product. This product doesn't miraculously make your injectors flow more CC/min.
Old Mar 14, 2009 | 01:03 PM
I always thought that IDC - Injector Duty Cycle - is the on time. Maybe I'm misunderstanding something, but I thought 100% IDC means, basically, full flow, or max flow. So, if a generic motor normally runs at, say, 65% IDC and the E-85 black box increases that by 30%, to, say, 85% IDC, then the motor should run OK on E-85. Perhaps not at max output, but it should run just fine.
It's not for me though. I would want, and would advise anyone else to get, an E-85 tune for our EVO's.
Old Mar 15, 2009 | 07:20 AM
mrfred's Avatar
Don't buy it. Its a waste of money and will probably destroy your motor if you try to use it.
Old Mar 15, 2009 | 05:12 PM
4-BNGR's Avatar
I appreciate the advice. In in NC; who can assist me with a proper E85 tune? Thanks in advance...
The_X_Effect
Aug 20, 2016 01:03 PM
dcdirtrider
Jun 4, 2015 09:45 AM
Mikami
Sep 27, 2014 05:28 PM
The_X_Effect
28
Aug 16, 2011 02:13 AM
atc1174
Jun 6, 2007 12:35 PM
