E85 Timing Maps
Old Apr 13, 2009 | 10:44 PM
mplspilot's Avatar
This is with 9.8 VIII turbo. ECU boost control with GM 3-port. (Dynoed about a month ago at 362tq/342hp on a mustang. I switched to a metal intake since then, which looks to provide ~0.5-1 psi higher than the rubber one from ~5000rpm and up, therefore increasing top-end power a bit...)
Edit: Timing is scaled as timing plus 10. (To move the graph higher, so that its easier to read for me, i did it back when i had neg timing at spool-up, DLL does not show neg values)):
Old Apr 13, 2009 | 11:01 PM
GST Motorsports's Avatar
mplspilot,
your log doesn't match the timing map you posted.
15* at 4k and 32*+ at 7k?
EDIT: nevermind I looked at the Value on the left and saw the scaling was different on timing.
Old Apr 13, 2009 | 11:34 PM
mplspilot's Avatar
Yeah, sorry, scaling is actual timing plus 10. Just easier to read it on the graph that way
Old Apr 15, 2009 | 11:10 AM
lan_evo_mr9's Avatar
Stock turbo 28psi tapering to 24-25.
Old Apr 15, 2009 | 11:33 AM
here ya go. I think I may be able to run a little more up top.
Old Apr 15, 2009 | 12:35 PM
kaymin's Avatar
hey jake!
heres mine for now. gonna fine tune soon
Old Apr 15, 2009 | 03:10 PM
Mpls- How much boost is that turbo running that you have the map and graph shown for?
Old Apr 15, 2009 | 04:40 PM
mplspilot's Avatar
It's in the middle picture, marked JDMMAP. I hit 30 psi on spool-up and it starts going down after 4500 rpm even though my WG duty is at 100% from there till redline. And by the redline it falls to ~21. I can crank boost even higher, i just wouldn't know what to do with all this tq it's freaking massive with this tiny turbo
Old Apr 22, 2009 | 02:51 PM
Here is my latest with no knock what so ever. She rips. This is with a peak of 27psi and tapering to 25psi.
Old Jun 19, 2009 | 09:56 PM
dwnfdrknss's Avatar
bump for more maps... i need a little more to soak in before i attempt my tune.
Old Jun 27, 2009 | 08:35 AM
NewLondon's Avatar
After switching to ethanol, I found that I needed to add in about 3-4 degrees to my timing map just to keep from misfiring. The extra fuel volume was too much at the miniscule timing I was having to run on pump gas. After I added the timing in, the car pulled clean and I was able to add an additional 5-6 degrees in most areas.
Marshall
Old Jun 28, 2009 | 09:37 PM
Marshall
At what AFR?
Old Jun 29, 2009 | 04:10 AM
NewLondon's Avatar
^high 10's/low 11's
Old Jun 29, 2009 | 10:10 AM
jid2's Avatar
You should try high 11's, like 11.8
Old Jun 29, 2009 | 10:57 AM
^high 10's/low 11's
On a gasoline wideband? Way too rich.
- Bryan
