Pros and Cons of going E85
Old Apr 6, 2018 | 07:37 AM
  #151
Biggiesacks's Avatar
She told me the name of the tests over the phone, but she might as well have been speaking another language lol. I remember one was a vapor pressure test and the other was a specific gravity test. I think there where 2 more that I have completely blanked on. TBH though even if i knew what kind of data the tests gave, my complete lack of chemistry knowledge prevents me from even knowing what kind of information could be directly or indirectly inferred by that data. So i figure ill just post the results for others to comb over and hopefully blackstone gives some insight too.
Old May 6, 2018 | 07:54 PM
  #152
theimmortalstig's Avatar
running ethanol 2 years only issue i have is a high duty cycle im using some f.i.c 1250 inj im @ 90sumn % at 25psi
Old May 6, 2018 | 08:10 PM
  #153
kaj's Avatar
kaj
I've heard quite a few "gunk" cases in California. I wonder if our oxygenated gasoline has an effect.
Old May 6, 2018 | 08:12 PM
  #154
kaj's Avatar
kaj
That could be right depending on the CFM or your turbo, though you should be making about 500whp, or more, at that point.
Old May 6, 2018 | 08:16 PM
  #155
Your correct I made 502 @the dyno last summer
Old May 6, 2018 | 08:20 PM
  #156
kaj's Avatar
kaj
Sounds like you have everything set up pretty well. I run 80% IDC, but lots and lots and lots of people run 90-95% and haven't had any problems.
Old May 6, 2018 | 08:24 PM
  #157
How can I get more from those injectors (f.i.c 1250) I tried using an aem 320 along with my wally 450 pump but engine failed same night cause it ran out of oil car felt faster with both pumps on tho but my IDC was in the 100&sumn range
Old May 6, 2018 | 08:33 PM
  #158
kaj's Avatar
kaj
The injectors can only do so much. Once you get to the IDC you are comfortable with, you're done. You will need a larger injector if you want more fuel.
I have some FIC 1450s for sale, though . I have the paperwork from RC after having them cleaned and tested. I've probably put less than 500 miles on them since. Let me know.
Old May 6, 2018 | 08:36 PM
  #159
2006EvoIXer's Avatar
How much are you boosting? And what mods do you have?
Old May 7, 2018 | 07:30 AM
  #160
RazorLab's Avatar
Been using it for 10 years now in CA on all my cars and have yet to see any of that.
Old May 7, 2018 | 11:19 AM
  #161
kaj's Avatar
kaj
We've had a hand full of local cars. One poor guy had TWO of his built engines go *poof*. His car spent more time at FFTEC than in his garage LOL. We laugh now...
Old May 7, 2018 | 11:45 AM
  #162
RazorLab's Avatar
I'm def not the "It's not happening to me so it doesn't happen" type of person so I know people are having issues. My question is I wonder what I'm doing differently?
I've never used any injectors other than ID in my 4B11 powered cars. I've never used any injectors other than RC in my 4G63's. I've never used fuel pumps other than Walbro.
My cars usually sit for week(s) between driving as well.
Old May 7, 2018 | 03:52 PM
  #163
kaj's Avatar
kaj
Oh, I gotcha. I wasn't taking your comment that way, sorry if my reply came off a certain way . Yeah, it's crazy! I've only used FICs. I've let my car sit for up to 6mos with e-85 in it, with the only damage being corrosion on the the metal parts of the my fuel hangar assly. The gunk thing seems to be super random which makes me even more nervous to the point I run pump gas in between each tank of 85, if it's been in there for any decent amount of time.
This is all with a functioning EGR, etc.
Sounds like we mostly know what causes it.. but predicting if that cause is something for us to worry about, at our individual pumps, is kinda sketchy. I don't even make much more power on it (I only use it at the track because it burns cooler) so I'm not even sure if it's worth it, for me.
tunermt
AEM EMS
16
Dec 13, 2025 01:11 AM
Smike
63
Apr 29, 2019 07:27 AM
SaltySilver
E85 / Ethanol
20
May 9, 2018 06:51 AM
RJSX
Apr 18, 2018 01:28 AM
ChiLAX
May 1, 2017 11:03 PM
