Mixed feelings on Walbro 255
Old Jan 24, 2012 | 02:39 PM
Evo_Jr's Avatar
Exclamation Mixed feelings on Walbro 255
So my plan was to go with a Walbro 255, do the "hardwire" hack, and run E85 with a second map for 93oct.
My tuner advised that the Walbro wouldn't be too reliable. Would make the numbers, and do the work, but not for long. He recommended to do a double pumper.
My questions is if that's true seeing you guys have done this for years/miles.
Want to know for sure before dropping $500 on another pump. I don't mind replacing a walbro every 6-12 months. That should give me time to buy the double pumper, but is it required now? What Would YOU dO?
Mods:
-Evo 9 Turbo
-100CC Injectors
-Basic bolts ons.
TIA!
Old Jan 24, 2012 | 03:07 PM
drb's Avatar
drb
With what turbo and what fuel injectors? I can tell you from experience that with the mods shown in my signature the 255 couldn't supply enough fuel on E-85.
Old Jan 24, 2012 | 05:14 PM
Evo_Jr's Avatar
Edited first post
Old Jan 24, 2012 | 05:25 PM
10isace's Avatar
I have similar mods and my 255 is good for it. I guess it depends on your future goals.
Old Jan 24, 2012 | 06:14 PM
Evo_Jr's Avatar
Double pumper def. Was not expecting it to be now. No real "future" goals for a while. Maybe piecing things all year but nothing urgent.
Thanks for the info sir!
Old Jan 24, 2012 | 06:25 PM
awdturbo8's Avatar
With that size turbo and injectors. A single 255 hardwired would be fine.
Old Jan 24, 2012 | 09:39 PM
drb's Avatar
drb
A single Walbro 255 with the relief valve modified/punched in would be good for your set up. I don't think that you would even need to rewire it.
https://www.evolutionm.net/forums/ev...ng-walbro.html
Old Jan 24, 2012 | 09:53 PM
Blue91lx's Avatar
I just posted this elsewhere, but do the Warlbro 400lph in tank. Out flows the modded 255s with ease, and will only run you around $150. A DP is becoming less and less necessary, especially for your application.
Old Jan 24, 2012 | 10:45 PM
TurboTravis's Avatar
Single 255 will feed this with NO ISSUES with NO MODS.
Old Jan 25, 2012 | 12:20 AM
deylag's Avatar
Yes I second a single Walbro. A true Walbro Fuel pump is super reliable and will provide you with enough fuel. I think your tuner is misinformed about Walbros. There are fake ones that are only good to be paperweights.
Old Jan 25, 2012 | 12:26 AM
evosam726's Avatar
For your setup you'll be just fine unless you want to go fp blk on e85 or big turbo e85
Old Jan 25, 2012 | 07:10 AM
Evo_Jr's Avatar
I bow to all of you guys. Greatly appreciated!
Old Jan 26, 2012 | 07:20 PM
mrfred's Avatar
a single walbro on stock wiring is fine for your mods. i'm almost three years into a single walbro on e85. it works as well as the day i installed it.
Old Jan 27, 2012 | 11:59 AM
cheb evo's Avatar
Agree that the 255 walbro should be just fine. MODs in my signature with the stock/unmodified 255, which has been running great on E85 for two years now.
Old Feb 21, 2012 | 06:54 PM
gunhaha's Avatar
Aren't those Walbros used in the dual pumps?
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
Skidonner90
25
Nov 10, 2015 02:13 PM
(03evo08)
Aug 10, 2014 03:03 PM
whitepwr
31
Apr 18, 2010 08:25 AM
MR.06MR
Jun 30, 2009 02:32 PM
