Going lean on wot on e-85
Old Apr 17, 2015 | 08:15 AM
  #31
manden's Avatar
Ethanol only contains about 2/3 of the energy of gas.
Old Apr 17, 2015 | 09:15 AM
  #32
mrfred's Avatar
Yep, I know that. Not sure what point you're trying to make.
Old Apr 17, 2015 | 09:19 AM
  #33
RazorLab's Avatar
Untill e85 is stabilized in production and sulfur free, ill stay away from it. The inconsistancy and quality is way too great.
More Ethanol for me then! Thanks!
I've also been using Ethanol for over seven years, also have shown proof that all that horsepoo internet slander about Ethanol is mostly BS.
It's a great fuel for us car enthusiasts. Either you believe the internet smear campaigns or you use it and enjoy it without issue.
Old Apr 18, 2015 | 01:25 PM
  #34
sik_z33's Avatar
I just started having the same problem with my evo X. Got tuned on e85 running id1000 injectors with AEM 320 pump a month ago. The car ran perfect for a month with solid 11.9-12.0 AFRs. Last week I did a roll race event and raced the car hard and while on the track everything was perfect. Driving home I did a pull and hit some type of hard cut (boost or fuel?) Afrs jumped to 14+ during the cut and went back to 12 when the car would resume. Now the car is running a full point lean ~13.0 in boost, my wideband (AEM) reads normal during idle and normal driving. I swapped relays to a newer Panasonic one from Mitsubishi with no improvement and was tuned on an updated OMRON relay.
What else could it be? Injectors have 5k miles of e85 through them. Pump and fuel sock are 1 month old. I tried a fresh tank of e85 from my regular station with no improvement. I would like to exhaust all options before saying tune. Any advise is appreciated!
Old Apr 18, 2015 | 01:58 PM
  #35
whtrice's Avatar
Veteran: Air Force
Ethanol may contain 1/3 less energy density (-)
but:
E-85 made 70 to 80 more WHP then when tuned with 91 oct petrol (+)
E-85 made 50 to 60 more WHP then when tuned with 100 oct petrol (+)
Oil didn't turn black with carbon as with running straight petrol. (+)
WW rear bumber stayed cleaner longer then with petrol. (+)
Spark plugs stayed cleaner then with running straight petrol. (+)
Piston tops have less carbon build up then with straight petrol. (+)
Cost of running E-85 @ ($2.29) is cheaper then with 100 oct petrol @ ($8.00) a gallon. (+)
Car ran cooler exhaust gas temps then with petrol. (+)
E-85 is > 2/3's a renewable resource. (+)
Old Apr 19, 2015 | 03:30 AM
  #36
manden's Avatar
but:
Most of it is true. And i like e85 too. If it is e85. Dont want e65. On your side of the pond the gas is of lesser quality, it just contains more dirt and sulfer.
Again. Until the e85 has stabilized as true e85 i stay with clean gas. 98 octane gas and e85 is same price here mpg.
My e85 engine ran great, no issues other that me being fakd on ethanol content every time i filled my tank. My ethanol sensor never was above 81% unless i mage the stuff myself, the sulfer content also dropped about 1%.
Everytime the ethanol content is 80% here all the guys hordes fuel like crazy. Its much better not to reward the manufactures for doing this, fake e85 will become true e85 much faster if people demands a prober quality like i do.
Old Apr 20, 2015 | 12:03 PM
  #37
whtrice's Avatar
Veteran: Air Force
Yes when California started selling E-85 at the pump around 2009 there were some quality issues.Consumers became more educated and have "called out" poor quality stations and reported them. Haven't noticed any sulfer contamination here. Most know our E-85 supply should be clear in color and how to check for % content of ethanol. We are also lucky here in California that we do not change to a seasonal fuel for E-85 like our gasoline does.
Old Apr 21, 2015 | 10:24 AM
  #38
manden's Avatar
I live in southern sweden. here they put 10% n-heptane in the gas and e85 for cold star properties In the winter "e85" is e60 or e65 with 10% n-heptane.
A good reason for the e85 in calif is the crappy 91octan law.
Old Apr 21, 2015 | 10:30 AM
  #39
RazorLab's Avatar
They lower ethanol percentage in the states in the winter months as well.
Currently E85 is at E77-E79 here in some of the California stations. Tuned appropriately, it is no issue.
Old Apr 21, 2015 | 10:51 AM
  #40
LetsGetThisDone's Avatar
But you burn 30% more of it. When we tuned my car for the new setup (in my sig) it picked up 35hp just by switching to E85, and adjusting fueling. No changes to timing or boost. E85 makes more power, plain and simple.
Old Jul 14, 2015 | 09:54 PM
  #41
kartectuning's Avatar
You need to check Fuel pressure when going lean.. might be dropping due to rubber fuel lines inside the tank going bad with the use of alcohol, also check alt voltages at high load high rpms
Old Jul 15, 2015 | 05:34 AM
  #42
mrfred's Avatar
The fuel lines or any other rubber components in the stock Evo fuel system do not go bad from running E85, at least for E85 available in the USA.
Old Jul 16, 2015 | 08:35 PM
  #43
He stated he was using a double pumper.. there is a Y hose in those kits that might be an issue.. measuring the fuel pressure ratio would be the best bet.. also the intake fuel filter can get clogged..
cheers
Old Jul 16, 2015 | 10:02 PM
  #44
cheers
OP has a single Wally 255. And this thread is a bit old. I hope he fixed whatever was wrong by now...
Old Jul 17, 2015 | 01:31 AM
  #45
asu11's Avatar
Yeah this was fixed a long time ago lol.
Tune was the issue. All good now
onefast2gdsm
Dec 30, 2016 09:17 AM
aquaMan219
Dec 18, 2016 05:28 PM
octaneblue_x
Oct 13, 2015 07:41 AM
Corrupter
Aug 29, 2015 07:40 AM
5LEEPERISAH23I
Sep 10, 2011 05:02 PM
