E100, what's the ideal afr?
Old May 29, 2012 | 12:21 PM
giangi's Avatar
Hi, i'm having the chance to source 99.9% pure ethanol here in Italy, so i'm thinking to swap to it from my actual fuel, normal e85. The car is a drag evo 6, 2.4lr with a borg warner s400 76 mm turbo, would i have real benefits in the change? My main concern is about afr on full load, on e85 i'm about 12.0 afr, is it correct also using e100 or i could go a little bit leaner? Any help would be much appreciated...
Thanks.
Old Jun 2, 2012 | 06:43 AM
PrimerSdime's Avatar
It's safe to run 12.5 afr's on e85. I would just tune for whatever makes the most power; whether it be 12.0 or 12.5.
Old Jun 2, 2012 | 06:49 AM
giangi's Avatar
Thank you very much for your answer, i will have some time for finishing the tune, second 2.3 block failed at 1090 whp, i think it's time for a 2.1 destroked with aluminium rods and this time 12:1 CR, not less......
Old Jun 2, 2012 | 07:57 AM
As soon as I can get my car to the dyno I'm going to do some probing with afr's for maximum power on e85. I see a lot of talk about it but haven't seen much evidence.
Old Jun 2, 2012 | 08:39 AM
Tuxevo's Avatar
Lol, you must not have looked very hard. Go to the alternative fuels section and soak it up.
Old Jun 2, 2012 | 11:22 AM
I have read plenty, and tune plenty. The only evidence I've seen is virtual dyno logs, which mean nothing to me.
Old Jun 2, 2012 | 11:40 AM
RazorLab's Avatar
Be more careful of pre-ignition on E100, compared to E85.
MBT is your best friend.
Old Jul 14, 2012 | 11:07 AM
motorspt's Avatar
What is MBT?
Old Jul 14, 2012 | 09:48 PM
Jim in Tucson's Avatar
Originally Posted by motorspt
What is MBT?
Maximum Brake Torque
Old Jun 11, 2013 | 04:07 AM
HsamehH's Avatar
Ethanol burn slow not fast like C16
Old Jun 21, 2013 | 07:02 AM
HsamehH's Avatar
i tested E90 vs E100 yesterday,
power increased but you shouldn't go past 12-11.9 afr,power dropped for me, 12 was my best part.
Old Jul 8, 2013 | 11:40 AM
Jeff_Jeske's Avatar
How much did your timing change?
Old Jul 8, 2013 | 12:55 PM
Kracka's Avatar
How are you getting 200-proof? That legally wouldn't even be considered a fuel here in the US.
Old Jul 8, 2013 | 01:02 PM
galantman03's Avatar
You can buy 100% directly from ethanol plants, or you can make it yourself
Prosdoc
Jul 1, 2015 03:33 PM
Evo VIII 4o1
Jul 27, 2014 03:36 PM
escodotcarter
Northeast Region
Apr 10, 2014 10:26 AM
iTune
E85 / Ethanol
58
Nov 16, 2013 05:58 AM
DvlInDskyz
E85 / Ethanol
Nov 13, 2013 08:50 PM
