E85 - P0171 too lean code - Long Term Fuel Trims + 12.5%
Old Oct 8, 2017 | 04:49 PM
  #61
mrfred's Avatar
Those trims are not unreasonable, especially for a big injector and a tune that probably didn't focus strongly on tight fuel trims. The hole in the MBC can, and should have been, accounted for in the tune, however, check valve isn't a bad idea as long as you use a quality one that has a very low opening pressure. Otherwise, I'd say just get a retune on closed loop.
Old Oct 8, 2017 | 06:34 PM
  #62
RazorLab's Avatar
MBC leak by design, they bleed off air to the WGA.
Old Oct 9, 2017 | 02:39 AM
  #63
Jp7's Avatar
Jp7
I understand, I'm just surprised blocking it off at idle had that much affect on the trims so quickly. Since it serves no function when the manifold is full of vacuum, I think it would be a more "pure" solution to put a check valve inline the control hose and only allow boost pressure in, right?
I understand completely, but rather than compensate in the tune I do like the check valve idea - any suggestions on a product?
I would think in an ideal world the MAF would account for all of the fuel determination.
Old Oct 9, 2017 | 07:05 AM
  #64
mrfred's Avatar
I've been happy with my Boomba Racing check valve that I use for a different purpose. The one in the link below is their smallest. Should work for you.
http://www.boombaracing.com/check-valve-5-mm-3-16/
Old Nov 27, 2017 | 12:07 PM
  #65
piper971's Avatar
Thought the more consistent fuel helped, but the code came back eventually. I have subsequently found a cracked injector o-ring. No code as yet, since I replaced it.
Kaezox
Jun 10, 2017 01:34 PM
aamoedo
Nov 7, 2014 03:51 PM
afmafia
17
Mar 10, 2008 05:10 PM
cpoevo
Aug 21, 2006 07:31 AM
