Flexfuel sensor install / return line modification for 7/8/9 above intake manifold
Old Oct 10, 2014 | 07:08 PM
Jp7's Avatar
Jp7
Thinking of installing my flexfuel sensor in/on the stock return line coming out of the regulator.
This would require either fabricating another "hard" return line with clips that mate to my sensor or brazing the correct mating pieces into the OEM hard line.
Because this sensor is not exactly small I would build a bracket that it can mount to, and mount one end to the 2 bolts that hold the throttle cable bracket to the intake manifold.
Anyone try anything like this or have any suggestions/opinions/ect.
Anything constructive is welcome.
Old Oct 12, 2014 | 12:06 PM
CDrinkH2O's Avatar
The flex sensor is equipped with tubing that accepts standard push lock EFI connectors. I recommend you bolt it to the firewall using the stud just above the heater feed and return hoses.
See here: https://www.evolutionm.net/forums/at...position-2.jpg
Use fuel hose and some barbed EFI connectors to plumb it into the return hose. This will be easier than trying to braze it into the return line above the intake manifold, which is actually cadmium plated steel tube.
Old Oct 13, 2014 | 06:29 AM
Jp7's Avatar
Jp7
I suppose I could do it that way, but "easier" isn't always the best solution.
If I went with my original idea I'd probably have a line made so I can replace the factory line instead of brazing it in. I have to think about this more.
Old Oct 15, 2014 | 08:12 AM
mrfred's Avatar
firewall is going to be a cooler location than above the intake manifold. i plumbed mine without efi connectors by using larger size hose in combination with reducing barb unions to connect to the factory diameter hose.
Old Sep 17, 2015 | 01:52 PM
Jp7's Avatar
Jp7
Project has been completed and documented better in another thread here:
https://www.evolutionm.net/forums/e8...l#post11475392
thedru13
Mar 18, 2019 05:08 PM
kpt6
Sep 2, 2013 12:55 PM
evoballer
Feb 15, 2012 06:49 AM
ArchieBabes
Evo X Dyno Results
36
Feb 21, 2010 08:22 PM
gvillevo
Dec 7, 2007 08:09 AM
