9 turbo + E85... 800cc injectors enough?
Old May 17, 2015 | 11:25 PM
alexc's Avatar
800cc injectors... how much power can they make on e85 stock 9 turbo?
originally i was planning on just a pump gas with stock evo 9 turbo tune for my car once i get my bolt on's since there closest e85 station is 20 min away but im having second thoughts. I already have the 800cc injectors cleaned and flow tested ready to go...
Old May 18, 2015 | 12:10 AM
kaj's Avatar
kaj
My general rule for injectors is cc/2 = pump gas whp. (91. 93 does considerably better). E85 usually requires 30% more. Personally, I'd expect up to 400whp on 91( with supporting mods and a large turbo). That would be about 300whp on e85. These numbers would put you around 80% duty cycle.
You can be more aggressive, of course. I BEAT on my cars, so I ask my tuner to take it easy.
I currently have 1450s and make about 360 on pump (limited by turbo size) and 450ish on e85, (also limited by turbo size), which is really close to my (cc/2)*.70 formula.
Sorry for the long reply LOL
To take advantage of e85, you needed much larger injectors because it burns a lot more. 1050s should allow you to (safely) max out that stock turbo.
All just my opinion, of course.
**edit: speaking of fuel pumps, the Walbro 255 flows surprisingly well. my numbers are on a single 255. i plan to do the "relief valve mod" as a bit of insurance. i don't push my car to the max very often, though.
Old May 19, 2015 | 06:37 AM
wilownu's Avatar
agreed with Kaj.
Check this out:
http://fuelinjectorclinic.com/flow-calculator
Old May 19, 2015 | 06:42 AM
ReaperX's Avatar
950cc is the smallest injector you can realistically go with on a stock 9 turbo and E85. At 25psi peak and 22 out the top my IDC was around 90%. That was with an aeromotive stealth pump and it was around 350whp on stock cams.
Honestly 1050cc will take you to 400whp when pushed with an adequate fuel pump.
Old May 26, 2015 | 08:21 AM
mrfred's Avatar
+1. 800 cc/min not enough if you plan to max out the turbo.
BeenWaitin4Evo
Sep 18, 2003 07:08 PM
feldguy
Sep 2, 2003 08:41 PM
