E85 Gauge w/ output for under $100
Old Jun 28, 2017 | 04:14 PM
  #136
mrb00st's Avatar
Originally Posted by evo8tanner
expectedv = ((((HZ-50.0)*0.01)*4)+0.5);
//Screen calculations
pwm_output = 1.11 * (255 * (expectedv/5.0)); //calculate output PWM for NEMU
^^^Is this the only line of code that needs to be edited if I want my output to the ecu to remain in Hz? Thanks for the assistance!
any reason u want it to output hz?
Old Jun 28, 2017 | 06:52 PM
  #137
kaj's Avatar
kaj
Anyone willing to situate the wiring for me LOL. are we soldering? tapping into pin outs? I haven't even pulled my ECU from the car, so no clue on what I'd be doing.
Old Jun 28, 2017 | 06:54 PM
  #138
mrb00st's Avatar
there will be a update coming this week or next. i will attempt to make a video on how to do the wiring and programming for everyone
Old Jun 28, 2017 | 06:58 PM
  #139
kaj's Avatar
kaj
Awesome. If i can actually see what to look for (how-to is a bonus), I will be doing this. Seems silly not to.
Old Jun 28, 2017 | 07:47 PM
  #140
4G63_EVO's Avatar
I did heat shrink and tap in pins for testing, planning to solder for the final product that goes in the car but I dont see why it wouldnt work, Ill post some pics of my very ROUGH work.
Old Jun 28, 2017 | 07:55 PM
  #141
kaj's Avatar
kaj
I am fine with mechanical stuff. I have to admit that is a bit intimidating.. .especially since I'm afraid I'll fry something
Old Jun 28, 2017 | 08:08 PM
  #142
Bonnie's Avatar
cool, thanks for your sharing, very helpful to me.
Old Jun 28, 2017 | 08:09 PM
  #143
4G63_EVO's Avatar
Have you wired up a gauge before
Old Jun 28, 2017 | 08:16 PM
  #144
kaj's Avatar
kaj
Not after pulling it apart and connecting wires to the circuit boards LOL
Old Jun 28, 2017 | 09:46 PM
  #145
4G63_EVO's Avatar
well, i guess thats one way to look at it, I dont have much experience with circuit boards or anything either, really none. and it was easy! so what if you fry something its like 12 bucks haha
Old Jun 29, 2017 | 10:07 AM
  #146
killerpenguin21's Avatar
I've had mine up and running for awhile, only issue is out of the car the readings are fine, but in the car my temp values are nonsensical and jump around while the ethanol % is pretty stable but will sometimes jump to random numbers.
It's odd because the function all seems to be fine, even verified against the test tube method, but something in the car is causing it to go haywire. Even switched to a shielded wire for signal from the sensor
Old Jun 29, 2017 | 02:11 PM
  #147
evo8tanner's Avatar
I am running an aem infinity ecu and will be utilizing a Hz input to the ecu
Old Jun 29, 2017 | 04:13 PM
  #148
4G63_EVO's Avatar
DId a test in some E85 and heres what im getting on the serial input, not sure whats going wrong
-1.50
Old Jun 30, 2017 | 03:08 PM
  #149
mrb00st's Avatar
-1.50
if u have the unit plugged into your laptop, you will have to ground the arduino to the car
Old Jun 30, 2017 | 03:22 PM
  #150
4G63_EVO's Avatar
I had it hooked up to my laptop but I grounded it on the negative cable on the power booster I was using to power the sensor. Touched it to the usb metal casing like previously said.
Why is this by the way, whats different then if I have it plugged into my USB on my head unit?
Any other ideas why its not working?
