Got my FiTronic the other day. So started my install. Thought I would share some of the stuff I was able to piece together. I will post up the display install after I get the parts I am waiting for.
I ended up running different fuel lines. I used my stock FPR. Going to clean up the install a bit more but was able to mount the flex fuel sensor off the back post on the fire wall. Some pics and parts.
Used this fitting to convert stock lines to AN fittings. Had to cut the ends off the lines. This is the part i used. https://www.jegs.com/webapp/wcs/stor...rsistYmm=false
Thanks. Install wasn't hard. Was harder figuring out the how. Challenging parts of the install was fitting the quick connects on the stock fuel lines. Odd angles. Also splicing into the ECU was a pain but not terribly difficult. I am working with TSCOMP. Tom gave me the fitronic install instructions but they don't cover the fuel fitting part.
Originally Posted by truitt
Badass install on the screen location, how difficult was the install? Do you have any tuners by to set it up?
