ECUflash tutorial for beginners
Old May 15, 2006 | 04:41 PM
  #31
colby's Avatar
No. Any counting would have to be implemented by the software. I have yet to flash an ECU "too many" times to the point where it will not reprogram. I don't see the flash longevity as a major problem for most people.
Colby
Originally Posted by ChrisF
Doesn't the ECU carry a flash counter or is that a software only function in software like ECUTek?
Old May 20, 2006 | 03:33 PM
  #32
anjapower's Avatar
what do the values in the speed limiter definition represent?
Old May 20, 2006 | 08:52 PM
  #33
viciousv322's Avatar
Originally Posted by MalibuJack
I want to add, you should add to your writeup that they should back up their stock ECU map, in at least 2 locations, its too easy to overwrite a stock map without renaming it, I'd request that there be an incremental save feature so you can't overwrite an old map unless you specifically want to.
Also, once the new definitions are available, there will be a metatable for the Immobilizer code, save that, write it down, keep it somewhere.. If you are playing with other peoples maps and write something to your car, you won't be able to start it without putting the right immobilizer code back in..
you should probably include this in the first post...if in fact it is necessary. (haven't hooked up to my car yet..)
Old May 21, 2006 | 12:03 AM
  #34
vboy425's Avatar
Old May 21, 2006 | 06:37 AM
  #35
MalibuJack's Avatar
I think its a digital representation of the vehicle speed, aka a VSS tick counter.. Haven't tried it yet..
Old May 21, 2006 | 11:01 AM
  #36
chrisw's Avatar
When loading a new ROM, do you need to maintain the imobilizer code? I have an EVO with the p0300 fix and I want to load a '03 EVO ROM that has not had the fix.
I can download the ROM from my ECU, and the only field I can read is the imobilizer code. The ROM I recieved has a different imobilizer code. I am guessing that I need to keep them the same and copy the value retrieved from the version I downloaded from my ECU. Right?
[edit]
Nevemind... you do need to change the imobilizer.
https://www.evolutionm.net/forums/ne...eply&p=3106410
Old May 21, 2006 | 11:16 AM
  #37
EFIxMR's Avatar
correct you must copy down the immbolizer code from your ecu and paste it into your new rom file.
be sure to keep a copy of your old rom.
this tutorial was just meant to familiarize people with the program, and is missing the process used to actually start swaping files and such, which I really just learned on the fly hence why its missing because at that point I didnt try it yet.
Old May 21, 2006 | 06:30 PM
  #38
vboy425's Avatar
one thing i knowest. the same software, two different computers. one of them read differently on the same rom as the other. One of the computer would show the immobilizer under misc and the other computer doesn't show anything. weird??
Old May 21, 2006 | 06:51 PM
  #39
RazorLab's Avatar
You have to have "Advanced" selected under Options to see everything.
Old May 21, 2006 | 06:53 PM
  #40
b0ostedEV08's Avatar
On and Off represents 510 kph
Old May 21, 2006 | 08:13 PM
  #41
BJai02's Avatar
Would you please explain what On and Off means in the table?
510kph? So that means no speed limit on our cars?
Old May 21, 2006 | 10:34 PM
  #42
vboy425's Avatar
no reason to mess with it anyway. i have taking my evo 170mph +. no fuel cut no nothing. i end up letting the gas go because two of friends sitting wiht me are scare and about to **** on themself.
Old May 21, 2006 | 10:36 PM
  #43
vboy425's Avatar
uhhm. i think u r right. thanks bro
Old May 22, 2006 | 06:04 AM
  #44
cfdfireman1's Avatar
Hex
Am I the only one that has to add .hex to name of a saved file to be able to open it again?
Old May 22, 2006 | 06:16 AM
  #45
fsugatorbait's Avatar
No.
