Fuel cut map
Old Jun 5, 2006 | 10:51 AM
Girlie's Avatar
Fuel cut map
Which map in the ecu controls the fuel cut function?
Thanks,
Girlie
Old Jun 5, 2006 | 11:08 AM
burgers22's Avatar
Hi
I would think the boost limit & boost cut delay timer are the ones to look at.
Firstly though, you should look at why ( if you are ) getting boost cuts. You should check your AFR & if nessercery run a better fuel pump, sutch as a walbro 255, in a later model Evo, realy think if you can run high boost on stock internals.
Are you getting boost cuts in your IX? I haden't read of those having a problem, even with 300whp.
MB
Old Jun 5, 2006 | 11:28 AM
Girlie's Avatar
Originally Posted by burgers22
Hi
MB
No, no fuel cut at all. I run 23psi on the stock pump daily, no problems.
I have just been looking over the maps and trying to get a better understanding of what each does and how they interact with each other. Just general knowledge.
Girlie
Old Jun 5, 2006 | 01:23 PM
andenbre's Avatar
if you look at the evo 8 maps you can get an idea of what is happening until more of the 9 maps are defined and flash is enabled for the 9
Girlie
Jun 6, 2019 11:11 PM
211Ratsbud
Nov 27, 2012 08:06 AM
Evo Girlie
Southeast Region
20
Oct 27, 2008 09:24 AM
Evo Girlie
May 23, 2007 10:26 AM
Girlie
Feb 19, 2006 11:06 PM
