Some good datalogging information
Old Jul 8, 2006 | 02:00 AM
mchuang's Avatar
Was browsing around and found this info on the web, thought it would be helpful to see definitions of some of the items we are messing with and grasp and idea of what they mean.
see attached
File Type: doc
Old Jul 8, 2006 | 08:07 AM
Evil_1's Avatar
Good info, thanks.
Old Jul 8, 2006 | 08:34 AM
cocoabro's Avatar
Helps alot. Thanks.
Old Jul 8, 2006 | 09:20 AM
Kings Fan's Avatar
Thanks for posting!
Old Jul 8, 2006 | 09:32 AM
Ludikraut's Avatar
Good find, thanks!
l8r)
Old Jul 8, 2006 | 09:56 AM
Ludikraut's Avatar
Alright, I took a quick peek at the doc, and there are a couple of things that I'd like to point out that I disagree with, or that I don't think apply to our ECU:
1.) I don't think the Evo ECU has the ability to advance timing, especially not on a knock sum of 1-3.
2.) The O2 sensor should not be used to tune your AFR, not even as a rough guideline. See this article: http://www.innovatemotorsports.com/resources/news3.php
l8r)
Old Jul 8, 2006 | 10:42 AM
mchuang's Avatar
l8r)
Mainly I was just pointing out the definitions, all the other info could possibly not relate to our ecu
Old Jul 8, 2006 | 11:21 AM
Ludikraut's Avatar
Yeah, I just wanted to point out things that don't seem to apply, so that newbies don't get the wrong idea.
l8r)
Old Jul 8, 2006 | 07:21 PM
nj1266's Avatar
What about the knock sum range of 0 to 43? Does this relate to our ECU?
I ask because I can tap a wire from pin 78 (knock Sensor) and connect it to oneof the LMA-2 open ports. The knock sensor reads voltage from 0-5v. If 0v=0 knock sum and 5v=43 knock sum, then it is possible to configure Logworks ro read knock counts.
But I need to make sure that this is the knock sum range on our ECU.
Old Jul 8, 2006 | 07:58 PM
mchuang's Avatar
I think DSM's had the range of 0 to 43 so I assume the EVO does too because that is the highest value knock sum can read afterwards the ecu says ***it nothing I can do about your sh itty map lol..Actually though the information I posted is regarding the TMO Logger I think which is for the DSM guys, So I assume all that information is similar to our cars since it is the same motor.
steve0677
Apr 2, 2017 05:33 PM
DatEvoKid
Jan 24, 2017 10:04 AM
ILovE WHEELS
Aug 7, 2012 05:02 PM
MikeyT
Southeast Region
Jan 19, 2012 08:25 PM
nightshift
Jun 20, 2009 11:32 AM
