MIVEC tuning
Old Oct 14, 2006 | 07:04 PM
  #106
JohnBradley's Avatar
Originally Posted by jcsbanks
I have a 340, but no map for it as the previous owner had it Ecutek'd. Aaron, do you have a 340 map or can you tell me what the differences were?
I dont have it in front of me, but the 340 map looked similar to the JDM GSR map with the early high advance like the RS. It was almost an RS map. I have it on my lappy still I think, I will post it later tonight.
Old Oct 14, 2006 | 07:27 PM
  #107
Ralph's Avatar
Originally Posted by -=SPECTRE=-
What mods do you have?
Intake, 3" TBE, MBC
Old Oct 15, 2006 | 02:53 AM
  #108
jcsbanks's Avatar
That would be great Aaron.
Ralph, I found spool up was earlier. On 98 RON (like 92-93 PON I gather) at 24-25 PSI it was hitting 1603 Hz up to 1000 RPM earlier than what you have posted in a high gear with stock airbox/lid removed.
Old Oct 15, 2006 | 06:39 AM
  #109
Dominos's Avatar
Try this map, it gave me a very flat torque curve and very early.
File Type: jpg
Old Oct 15, 2006 | 06:41 AM
  #110
Dominos's Avatar
Can't get it any bigger for some reason
Old Oct 15, 2006 | 09:38 AM
  #111
Ralph's Avatar
Maybe because of the higher boost you'll hit it sooner? I'm probably only running 22~psi. It seems my gauge sits at "1"psi when car is off.. damn autometer. Time for a new gauge .
Old Oct 15, 2006 | 09:43 AM
  #112
Ralph's Avatar
Let me ask this to someone whose running 23~psi or 24. What load cell are you in at these boost levels? And at what rpm :O
Old Oct 15, 2006 | 09:51 AM
  #113
This power curve:
With this map:
This is the map like three or 4 generations ago now, but it still works really well. I have been working on flattening out the torque curve (ridding the dip at 3900). For the record it made peak torque at 3200 and peak power at 7054. Notice how power tapers at peak and then flattens out. Not my car BTW.
Power numbers and name removed.
Old Oct 15, 2006 | 09:55 AM
  #114
Ralph's Avatar
Originally Posted by JohnBradley
This power curve:
:img:
With this map:
:img:
What kind of mods were on that car and would it be ok to try that map on 91 ? So far I have a couple mivec maps/tunes that I'll be testing at the track in a few weeks to see which works out better for me..
Old Oct 15, 2006 | 12:19 PM
  #115
-=SPECTRE=-'s Avatar
I think the only way to fine tune MIVEC is going to be on a chassis dyno.
Old Oct 15, 2006 | 03:24 PM
  #116
jcsbanks's Avatar
For wide open throttle, which is only really what bothers me for MIVEC tuning, then tarmac based datalogging of acceleration can be very useful and you can see clear differences between GSR and RS maps. I'm not really bothered about holding it at each RPM zone with unrealistic loads for ignition timing either as it tends to produce overly retarded maps. It is nice to sit on a chassis dyno and do whatever testing you want without the constraints of the law and traffic though
Old Oct 15, 2006 | 05:25 PM
  #117
evo ippo's Avatar
hey guys and gals i was wondering how do you copy a image of the maps so i can post it up so i can get your opinion about it
Old Oct 15, 2006 | 05:48 PM
  #118
Ralph's Avatar
Cool
Highlight the window you want to screenshot, hold alt and then press print screen - this should be above your home/end/insert keys.. nothing will happen.
Then click the windows start button, click run, type in mspaint. When this opens click on edit then click paste. After this you'll want to Save As use extension .JPEG or .JPG... save it to somewhere on your computer. Someplace like your Desktop
Now if you don't have a photobucket account, make one. www.photobucket.com
After this is done you can upload pictures to the account, its very simple.. Then after uploading a picture you have links to the pictures. Copy the one that begins with [ IMG ] but without spaces..
Begin a post on evolutionM and copy that code in wherever you want the picture to be inserted..
Good luck
Old Oct 15, 2006 | 05:51 PM
  #119
Evo_Jay's Avatar
Good luck
You dont have to host your pic on a 3rd party server, you can host in on EvoM.net.
Old Oct 15, 2006 | 05:54 PM
  #120
Ralph's Avatar
The maps I've saw hosted on here come out very small.. can't read load cells when the colors are dark.
Check page 1 for the RS MIVEC map.. hard to read
