engine immobilizer quick question?
Old Jul 30, 2006 | 09:31 PM
ohthree's Avatar
if you scan your exact flash to another car will the car not start due to engine immobilizer?
Old Jul 30, 2006 | 09:39 PM
hondafan's Avatar
that's right. all you have to do is enter the code from the stock ROM of the car you're flasing to onto your map and it should work.
Old Jul 30, 2006 | 10:12 PM
ohthree's Avatar
where is that code?
Old Jul 30, 2006 | 10:18 PM
RazorLab's Avatar
Old Jul 30, 2006 | 10:23 PM
ohthree's Avatar
thanks you rock, and every car has its own code for this?
Old Jul 30, 2006 | 10:26 PM
emagdnim8's Avatar
/\ how come my ecuflash doesn't have that immobilizer option?
Old Jul 30, 2006 | 10:28 PM
ohthree's Avatar
same here, i just looked and mine doesnt have it. i uploaded the tutorial.
Old Jul 30, 2006 | 10:29 PM
ohthree's Avatar
also does the 03 models come up as 04 since the ECU stock setting are exactly the same for both years?
uterus!'s Avatar
You have to set your user level to developer in the options, then restart the program.
Old Jul 30, 2006 | 10:31 PM
emagdnim8's Avatar
Originally Posted by uterus!
You have to set your user level to developer in the options.
It is on developer. The immobilizer option shows up when I load one map, but not when I load my stock map. Should it not show up when I load my stock map?
Old Jul 30, 2006 | 10:43 PM
RazorLab's Avatar
It should load for every map. Set it to developer, quit the program and relaunch.
ohthree's Avatar
if i read my ecu, and write it in beginner does my engine immobile code follow? or do you have to use developer?
Old Jul 30, 2006 | 10:45 PM
RazorLab's Avatar
Developer is only for the program to show other options. Your ROM has every option in there no matter what you have the app set to.
Old Jul 30, 2006 | 10:48 PM
ohthree's Avatar
so you dont want to mess with the engine immbolizer code cause if it changes you cant start your car?
Old Jul 30, 2006 | 11:24 PM
RazorLab's Avatar
Always write down your immobilizer code.
