Logging boost with EvoScan
Old Aug 17, 2006 | 03:02 PM
ONRAILS's Avatar
Is it possible? At first i thought you could but my car was only reading 14.1psi on the baraometer.
Or is that my actual boost?
Old Aug 17, 2006 | 03:06 PM
cpoevo's Avatar
The barometer reading is the outside air pressure. Evoscan does not log boost. You need a seperate boost gage.
Old Aug 17, 2006 | 03:11 PM
jcsbanks's Avatar
UK/JDM IXs do log boost from the car's MAP sensor in Evoscan if you edit the xml file. It is a nice sensor, goes over 30 PSI boost.
The barometer is also in the MAF sensor, the difference is that the reading drops when you are high revs/load, whereas a baro reading from outwith the intake system would not.
Old Aug 17, 2006 | 03:23 PM
ONRAILS's Avatar
Cool, I was like WTF 14lbs...
Anyways thanks for the quick responce guys.
Old Aug 17, 2006 | 05:01 PM
C6C6CH3vo's Avatar
Yeap, baro reading is accross the MAF, ussually a little less than 1 atmosphere - 14 psi
Old Aug 17, 2006 | 05:05 PM
nj1266's Avatar
Can the JDM MAP sensor be installed on the USDM Evo 8 and use it to log boost? Is the harness plug the same? That would be great if it works.
Old Aug 17, 2006 | 08:32 PM
-=SPECTRE=-'s Avatar
get a zeitronix wideband + MAP for logging boost, that's what i'm doing
Old Aug 17, 2006 | 10:10 PM
MalibuJack's Avatar
I'm actually working on getting the sensor right now to see..
Old Aug 17, 2006 | 11:29 PM
nj1266's Avatar
I have an Innovate LM-1 and I have a 3 bar GM MAP and I am logging and viewing my boost. But It will be a much cleaner approach if the JDM MAP sensor would work. You do not have to tap into your existing MAP harness and get a wire to the MAP sensor. Just swap the JDM MAP sensor and log the MAP from the OBD2 port. Very clean and very easy.
Old Aug 18, 2006 | 06:55 AM
MalibuJack's Avatar
Well, I have the sensor part number, trying to source the part from Japan or Taiwan for a reasonable price. I do know that the sensor would have to be recalibrated, and I have not yet found the map v to bar translation table yet.. Since it exists in the JDM ECU it will likely also be in the USDM ECU and be fairly easy to calibrate by copying the values once the map is found.
Old Aug 18, 2006 | 08:51 AM
ScrappyJack's Avatar
Malibu - You might want to try giving RRE a call. They have been dealing with JDM OEM Mitsu pieces for several years.
Old Aug 18, 2006 | 09:05 AM
jcsbanks's Avatar
What do your VIIIs read when you are at about atmospheric on the MAP input? I've previously posted the scaling of the JDM sensor, with a 5V supply this scaling should work. It is just if your ECU doesn't anything with the values that you'd need to work on scaling.
Old Aug 25, 2006 | 04:56 PM
mrfred's Avatar
I have a contact in Japan that I have been using for three years. PM me if you want me to check on what price I can get.
boostn6262
May 29, 2012 10:08 AM
clubEVO93
Oct 18, 2010 02:01 PM
whitersevo
May 29, 2006 11:57 AM
dave9172
Apr 19, 2005 07:40 AM
herbal77
21
Dec 21, 2004 05:16 PM
