Octane number update information - 1-3=increment/4-5=no change/6=decrement
Old Aug 30, 2006 | 06:06 PM
  #31
tuning g's Avatar
when using evoscan is it just the obd II cable only or both
Old Aug 30, 2006 | 07:37 PM
  #32
andenbre's Avatar
I just use the obd II portion of the cable. it seems to log slower with both plugged in
Old Aug 31, 2006 | 04:23 AM
  #33
tuning g's Avatar
thanks andenbre and how do you convert it to excel
Old Aug 31, 2006 | 04:26 AM
  #34
tuning g's Avatar
by the way on the IX which map is the main ignition map and what do the other 2 do i noticed it has three ignition maps ign 1,2 and 3 lo and hi octaine. Can you share this information with me please
Old Aug 31, 2006 | 05:26 AM
  #35
jcsbanks's Avatar
#2. #1 warm up. #3 fault. That is our best understanding so far.
Old Aug 31, 2006 | 05:52 PM
  #36
tuning g's Avatar
thanks guys working great now
Old Aug 31, 2006 | 07:14 PM
  #37
MalibuJack's Avatar
FWIW I never noticed any difference in logging speed with both connectors hooked up..
Old Oct 5, 2006 | 04:08 PM
  #38
Nogi's Avatar
The octane number recovery also seems to have a load component in addition to the timer. I was logging a friend's car and watching the octane number head toward 250 or so as usual with his tune. Then we drove around with light load and waited for it to creep back up to 255 - which it did. Then, we 'knocked' it back down to 250 and got out of the gas again for a while. It didn't come back up at all after a few miles of light driving. Surprisingly, when he got back into the gas hard, it immediately shot up to 254 over a couple of seconds.
We repeated this a few times. Getting completely out of the gas and then loading it pretty heavy (but not to the point of knock) made the octane number recover faster (in fact, immediately) than waiting for the timer. Interesting.
Old Oct 6, 2006 | 01:48 AM
  #39
jcsbanks's Avatar
I saw this too, and the code supports the behaviour. The knock control and the octane control are both constrained by limits such as load, RPM, coolant as you say. It won't show knock sum or adjust octane unless there is some load on the motor.
Old Oct 7, 2006 | 12:16 AM
  #40
ST's Avatar
ST
how are the initial octane numbers calculated and stored?
tuned a vehicle the past week where even after a battery reset, its previous octane value (in this case around 74%) was still prevalent. my friend and i speculated that somehow someone erroneously placed in 89oct gas or so, thus the ecu "set" this value intially after a start. Either this or maybe that this value is stored in long term flash memory.
Old Oct 7, 2006 | 02:25 AM
  #41
jcsbanks's Avatar
When I unplugged my ECU momentarily, it went back to the initial value that I'd flashed the ROM with. All the ones I've seen default to 255 or 100%.
tenney
May 12, 2016 03:29 AM
06 SLOW EVO
Aug 6, 2007 09:35 AM
vroomevo
Apr 27, 2007 12:44 PM
RedV
Apr 2, 2007 10:38 AM
dubbleugly01
Dec 22, 2006 08:19 AM
