Throttle hang and the Idle Stepper Table
Old Nov 9, 2007 | 08:10 AM
  #211
MR Turco's Avatar
How does this look? I changed the map to reflect load and coolant temp. I think the load values make sense right?
I am going to load it on this weekend and try it. I forgot my cable or i would have done it for the ride home from work.
Old Nov 9, 2007 | 08:17 AM
  #212
Jorge T's Avatar
Volts as in tps volts ^ That makes sense, but the load16 scale intervals still look off at least on the 008 rom, iirc all the axis are in whole numbers
Old Nov 9, 2007 | 08:23 AM
  #213
MR Turco's Avatar
Yeah it still wouldnt make sense because at idle the tps should always be zero.
Old Nov 9, 2007 | 08:52 AM
  #214
Evo_Jay's Avatar
Nice. THat is what i was thinking after tepha figured out the new scale. Im gonna copy that and reflash me car tonight.
Ill report back.
Old Nov 9, 2007 | 12:27 PM
  #215
NineWorks's Avatar
All this really makes sense...
I'll give a try tomorow
Edit :
Don't you think we should keep the last raw (hi load) fully open to let more air inside at WOT ?
Old Nov 9, 2007 | 03:53 PM
  #216
Evo_Jay's Avatar
Edit :
No thats what is creating the throttle hang.
Old Nov 9, 2007 | 05:45 PM
  #217
tephra's Avatar
isn't 41 deg cel a bit cold? i know I get upto 80 just cruising around...
Old Nov 9, 2007 | 06:59 PM
  #218
Evo_Jay's Avatar
41 C = 105 f
Old Nov 9, 2007 | 07:08 PM
  #219
Jorge T's Avatar
coolant temp = 176*F-190*F
http://www.autoshop101.com/forms/h26.pdf
Old Nov 9, 2007 | 08:59 PM
  #220
Evo_Jay's Avatar
I think you only have to make the changes to the far right row, the 41 C row.
If this table is like any other table, if the car goes past the last row (ie over 41 C), it uses the setting in the last row.
Old Nov 10, 2007 | 01:01 AM
  #221
tephra's Avatar
sure but its a bit redunant isn't it?
I mean why have all that stuff from -8 to 41 but nothing from 41 to say 60...
anywho
Old Nov 10, 2007 | 08:04 AM
  #222
MR Turco's Avatar
I dunno. I think the range is a little weird too. As long as it works i will be happy.
Old Nov 11, 2007 | 12:20 AM
  #223
inco9nito99's Avatar
Seems to work fine for me.
Old Nov 11, 2007 | 06:19 AM
  #224
NineWorks's Avatar
Works fine for me too, the cold start idle is back again and the hang is fixed
Old Nov 11, 2007 | 06:32 AM
  #225
MR Turco's Avatar
Awesome! i havent even tried it yet, roommate has had the tactrix cable all weekend. I will try it tonight.
