Throttle hang and the Idle Stepper Table
Old Feb 1, 2008 | 09:41 AM
  #256
TouringBubble's Avatar
I'd never noticed that in my car before I changed the settings. Maybe it was just a coincidence.
Old Feb 3, 2008 | 10:17 PM
  #257
jose2187's Avatar
evo 8 ????
Hey guys, I have a 2005 evo 8 will this chart work with my car or only the evo 9
Old Feb 21, 2008 | 06:15 PM
  #258
mr2driver's Avatar
'06 with 2200 miles. Only mod is a k&n filter. I have had the throttle hang since day one. The table below is what I put in and it worked for me. At cold startup it idled around 1400rpm. I drove around the neiborhood until it got warm, then I drove around the block running through the gears and the throttle hang was completely gone. So then I drove it to Wal-mart and back and no more throttle hang, no idle problems. I will give more feedback after I drive it back and forth from work tomorrow.
Old Feb 22, 2008 | 11:07 AM
  #259
bnice01's Avatar
Let me ask a question after rescaling your idle stepper table, how is your cold starts now?
Comparing the stock idle stepper table (TPS/RPM) and the rescaled one (coolant/load). It looks like the steps have drop alot in the colder cells during idle. Load is usually around the 30's @ idle and TPS % is in the low teens.
Old Feb 26, 2008 | 08:42 AM
  #260
mr2driver's Avatar
I haven't had any trouble with cold starts, but then again, the coldest it got so far was about 50 degrees.
Car has been driving great so far, only side effect is no throttle hang.
Old Feb 27, 2008 | 06:37 PM
  #261
mr2driver's Avatar
I am using Scan Tech for these numbers, so I am not sure how accurate it is, but it's 39 degrees here right now, I went out and let the car warm up to temp and at idle....
800rpm
20.0 % Load
0.0 % Throttle Position
I don't really have the time tonight, but I will try flashing it back to stock and see if the above information changes. The car started up and idled at about 1400 and it slowly tapered down as it warmed up to temp to 800rpm.
Old Mar 25, 2008 | 11:10 AM
  #262
travman's Avatar
Fixed..
Old Mar 25, 2008 | 12:21 PM
  #263
GrocMax's Avatar
Keep in mind there are adaptive routines for the ISC control. And the reason the stepper lookup table doesn't progressively get larger with colder coolant temps is the FIAV.
There is most likely a 'dashpot' function table somewhere.
Old Apr 11, 2008 | 01:53 AM
  #264
gogolio's Avatar
So, did anyone ever fix this without any further problems? I Have had my evo 9 tunned to about 335awhp and my boost up to 25 psi, and i'm struggling not to kill myself through fast shifting because if i take a second longer with my car in gear after i lift off the throttle it keeps shooting forward like a damn rocket .
Please let me know if someone did anything that actually worked
Old Apr 11, 2008 | 02:17 AM
  #265
evo828's Avatar
If the car doesnot immediatelly respond when you slightly lift-off the throttle or your RPM hang when you shift under heavy driving - then your idle stepper lookup table should be flattened out to 40 in the most right column - so when the engine is warmed up the stepper is not progressivelly opening itslef with the load. The table attached is for my evo 8 so yours maybe slightly different. You should try to find the optimum value for yours setup
Attached Thumbnails Throttle hang and the Idle Stepper Table-idle-stepper.jpg
Old Apr 11, 2008 | 06:23 AM
  #266
gogolio's Avatar
Still looking
Thanks man. Will try.
Have you actually tried this on your car and made sure it works? You can see that a lot of guys tried different stuff in that same direction if you read this thread, and i'm not sure any of those ever work 100%
Does anyone that have an evo 9 have any suggestions, since they are the ones that seem to have that problem by default?
Old Apr 11, 2008 | 06:30 AM
  #267
gogolio's Avatar
Question
Originally Posted by Bonestock!
Mine used to do it, Once I got tuned it stopped for months. Recently after getting my lean spool adjusted & adding the GM 3port it started again. Its definetely SOMETHING in the MAP. Now I just have to find out what it is.
Bonestock. Have you found out yet, or still struggling?
Old Apr 11, 2008 | 06:48 AM
  #268
evo828's Avatar
yes I have it in my car - the table is from my map. With the stock setup it was holding high rpm when shifting.
Old Apr 11, 2008 | 07:30 AM
  #269
gogolio's Avatar
Thumbs up Thanks
Thanks man. Will try it tonight and let you know if it works for my evo 9.
Old Apr 12, 2008 | 10:29 AM
  #270
mr2driver's Avatar
I have an Evo 9. I have my stepper table set like I posted above since February and I have not experienced any problems with idle, cold starts, or that annoying throttle hang.
