Highest safe level of PSI on 91.
Old Oct 24, 2006 | 10:55 AM
  #31
macnewma's Avatar
The reality is that this question has too many variables. If this is with a clean, cool IC, cool day, on its first run that will only last approximately 12.5 seconds, you can probably run pretty high boost without knock, assuming a good tune.
Now, if you want to run with ambients in the 100F range for 30 minutes of WOT and near-WOT, you are much more likely get a pretty hot charge going at some point and then you will see knock.
Old Oct 24, 2006 | 11:07 AM
  #32
mchuang's Avatar
Originally Posted by nj1266
Just for comparison purposes here is what I have:
rpmx100-----Load------Tim------AFR
35-37--------240ish-----4-2-----11.4-11.5
40-45--------220ish-----5-6------11.4-11.5
45-50--------220ish-----4-5------11.4-11.3
50-55--------low220s---6-7------11.3
55-60--------210-213---7-9------11.3-11.2
60-65--------205-196---9-12-----11.2
65-70--------195-180---11-16----11.2-11.1
70-75--------179-171---16-18----11.1-10.97
On some runs I do get knock counts of 3-1 range @ peak boost/torque and sometimes @ the top of the rpms range. On other runs no knock counts up top at all. The boost is set @ 21.xx and rarely goes to 22 psi. I run the car on 93-94 octane that I mix @ the pump.
The car consistently puts down about 300 whp and 280ish torque on the DLL dyno plot. Oddly, the most impressive dyno plots are the ones that have a bit of knock sum in them
What is the highest load you see. I saw 269 for first time on the run where I encountered 5-6 knocks where as normally it doesnt hit over 250 and that is with error protection lol.
Old Oct 24, 2006 | 05:38 PM
  #33
nj1266's Avatar
The highest I have seen is 256. It happened on a few runs, but normally it is around 245. But I run the stock air box and stock filter.
riceball777
25
Feb 15, 2011 08:51 PM
landis507
20
Jan 30, 2009 09:27 PM
GgreyEVOIX
28
Dec 30, 2006 02:43 PM
icedomin8r
Sep 19, 2006 04:00 PM
w2pac12345
Aug 1, 2003 08:48 AM
