Gauges for Evoscan v0.97
Old Oct 17, 2006 | 11:48 AM
TTP Engineering's Avatar
Just thought I would put up a thread for anyone that has created custom gauges. If you are interested in sharing them with the forum, please feel free to post them up here.
I for one, have not even used GaugeView1.xml and I do not see it in my 0.97 update. Anyone have an idea where I can find this xml file?
Old Oct 17, 2006 | 11:57 AM
Mad_SB's Avatar
I tried to mess around with some gauges the other night, got a few custom ones created but I coul dnever figure out how yo get the background (the square the surrounds the gauge) to take any color other than the nasty gray so I gave up.
I really want to set the background area to transparent or black to match my desktop background. I read through the dundas gauge info and it looks like it is a container property, but the way it is implemented in evoscan does not seem to allow you to modify the properties of the container....
I'll look and see if I can find the file you are looking for, you may just have to create it by creating a layout and saving it or something....
Old Oct 17, 2006 | 12:06 PM
l2r99gst's Avatar
I was looking for that myself, since Evo4Mad said that he created a custom gauge with state indicators, showing different colors for knock. I didn't find the file, either. I think he forgot to include it in the install.
Eric
Old Oct 17, 2006 | 12:14 PM
I know some people got them though since they were telling me they were using it to test my remotEflashes.
Old Oct 18, 2006 | 05:37 AM
Mad_SB's Avatar
here is a gauge template I created this A.M.
http://home.comcast.net/~lexx1313/Gr...peed-knock.xml
it has:
tach
knocklight with color based state
knock sum text with color based state
speed
tps text wtih color based state
Just save the xml file to your EvoScan v0.97\GaugeTemplates folder then go to gauges, add/edit, select "Graphite-tach-speed-knock", assign knock sum to both knocklight and knocksum, tps to tps, speed to speed, engine speed to default.
Not very pretty but it does show how to use states and create a simple combo gauge..
Old Oct 18, 2006 | 06:59 AM
This is what I was emailed for the knock gauge. It does not work like this for me.
<?xml version="1.0" standalone="yes"?>
<NewDataSet>
<Table1>
<Top>22</Top>
<Left>1370</Left>
<Width>467</Width>
<Height>332</Height>
<GaugeTemplateFileName>KnockIndicator</GaugeTemplateFileName>
<GaugeRefreshRate>0</GaugeRefreshRate>
<DataRequestItemsSerialized>&lt;SOAP-ENV:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:clr="http://schemas.microsoft.com/soap/encoding/clr/1.0" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"&gt;
&lt;SOAP-ENV:Body&gt;
&lt;a1:ArrayList id="ref-1" xmlns:a1="http://schemas.microsoft.com/clr/ns/System.Collections"&gt;
&lt;_items href="#ref-2"/&gt;
&lt;_size&gt;1&lt;/_size&gt;
&lt;_version&gt;1&lt;/_version&gt;
&lt;/a1:ArrayList&gt;
&lt;SOAP-ENC:Array id="ref-2" SOAP-ENC:arrayType="xsd:anyType[16]"&gt;
&lt;item xsi:type="a3:Globals+GaugeDataItem" xmlns:a3="http://schemas.microsoft.com/clr/nsassem/EvoScan/EvoScan%2C%20Version%3D1.24.0.0%2C%20Culture%3Dneu tral%2C%20PublicKeyToken%3Dnull"&gt;
&lt;GaugeType&gt;StateIndicator&lt;/GaugeType&gt;
&lt;TemplateName xsi:null="1"/&gt;
&lt;GaugeName id="ref-4"&gt;Color Indicator&lt;/GaugeName&gt;
&lt;GaugePointerName href="#ref-4"/&gt;
&lt;DataItem id="ref-5"&gt;Knock Sum&lt;/DataItem&gt;
&lt;DataKey id="ref-6"&gt;KnockSum&lt;/DataKey&gt;
&lt;Min&gt;0&lt;/Min&gt;
&lt;Max&gt;50&lt;/Max&gt;
&lt;/item&gt;
&lt;/SOAP-ENC:Array&gt;
&lt;/SOAP-ENV:Body&gt;
&lt;/SOAP-ENV:Envelope&gt;
</DataRequestItemsSerialized>
<Reserved1 />
<Reserved2 />
<Reserved3 />
<Reserved4 />
<Reserved5 />
</Table1>
</NewDataSet>
Old Oct 18, 2006 | 08:45 AM
Mad_SB's Avatar
I pasted that into a new xml in the gaugetemplate folder and got an exception when I tried to add that gauge.
Give the one I posted a link to a shot and see if you have better luck with it.
Old Oct 18, 2006 | 09:53 AM
It gave an exception at first, but when I edited out all the "-" and "+" in the code, it worked.
The crappy part appears to be that you have to manually select what does what in the gauge each time you open it.
Old Oct 18, 2006 | 10:49 AM
Rob W.'s Avatar
TTP: can you post the actual file, now that you've fixed it.
Also, if you save the gauge as a Gauge Layout, it will remember all the channel assignments. (I just tried it)
Even though it's mostly eye candy, I love playing with this stuff... I just haven't had time lately. I spent a lot of time trying to make the ones in 0.9 work, before finally realizing the states and numeric stuff wasn't enabled yet.
Old Oct 18, 2006 | 11:53 AM
Mad_SB's Avatar
States are working now, I would like to figure out how to do a peak hold function. The biggest gripe i have is not being able to set the gauge container color....... Hope that gets fixed.
Old Oct 18, 2006 | 01:10 PM
Rob W.'s Avatar
I spent a lot of time messing around with the various signal filters and conditioners trying to simulate a peak hold, but they didn't really seem to have any effect at all (this was with v.9). Peak hold is critical for knock counts.
Old Oct 19, 2006 | 04:04 PM
evo4mad's Avatar
Ok I will add a peak hold feature.. that will be awesome! which means you will be able to have two pointers on the gauge... one for actual and one for peak hold!
I will do some extreme testing on the next version to make sure all my default gauge containers get included in the installer.
TTP: The gauge dataitems are remembered in the GaugeLayout.. make sure you press save.. you can even see them in the file you posted... "DataItem id"
also attach it as a file.. this forum messes with the xml special characters. Or using the forum "code" block feature will help.
Also if your settings aren't saving make sure this blank file exists:
c:\program files\evoscan\evoscan v0.97\SavedSettings\EvoScan.xml
Edit: turns out the "savedsettings" dir/ was not created during install
Also the background container thing I'll check this out..
Old Oct 19, 2006 | 11:58 PM
codgi's Avatar
I was going to point that out. Forums have to do it though to prevent against Cross Site Scripting attacks.
How are you checking for bug regressions between versions Evo4Mad? That's going to be a full time job going forward and you probably will need to get a full time tester to look at that stuff.
Old Oct 20, 2006 | 12:38 AM
RoadSpike's Avatar
I haven't worked with evo scan but i do know xml
Shouldn't those &gt; and &lt; be < and > respectively? if so it would look like this
<NewDataSet>
<Table1>
<Top>22</Top>
<Left>1370</Left>
<Width>467</Width>
<SOAP-ENV:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:clr="http://schemas.microsoft.com/soap/encoding/clr/1.0" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
<a1:ArrayList id="ref-1" xmlns:a1="http://schemas.microsoft.com/clr/ns/System.Collections">
<_items href="#ref-2"/>
<_size>1</_size>
<_version>1</_version>
</a1:ArrayList>
<SOAP-ENC:Array id="ref-2" SOAP-ENC:arrayType="xsd:anyType[16]">
<item xsi:type="a3:Globals+GaugeDataItem" xmlns:a3="http://schemas.microsoft.com/clr/nsassem/EvoScan/EvoScan%2C%20Version%3D1.24.0.0%2C%20Culture%3Dneu tral%2C%20PublicKeyToken%3Dnull">
<GaugeType>StateIndicator</GaugeType>
<TemplateName xsi:null="1"/>
<GaugeName id="ref-4">Color Indicator</GaugeName>
<GaugePointerName href="#ref-4"/>
<DataItem id="ref-5">Knock Sum</DataItem>
<DataKey id="ref-6">KnockSum</DataKey>
<Min>0</Min>
<Max>50</Max>
</item>
</SOAP-ENC:Array>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
<Reserved1 />
<Reserved2 />
<Reserved3 />
<Reserved4 />
<Reserved5 />
</Table1>
</NewDataSet>
Old Oct 24, 2006 | 10:41 AM
Rob W.'s Avatar
As Evo4Mad said, I manually added a SavedSettings directory, then copied an XML file into there, renamed it "EvoScan.xml", and deleted it's entire contents. The first time you rerun the program, you'll get an error message and the channel list will be blank. Just close and rerun it. Now, it's back to normal operation, except all the settings save perfectly!
THANKS!
