AEM UEGO Serial Cable Instructions
I bought a serial cable from a computer store and tore it apart. Use a screwdriver to pop the old connector out, and dremel the inside of the plug to fit your connector in (or re-use the one in the cable). Dremeling the inside will also allow you to yank the cable out of the plug. I put the plug back in the cable along with some hot glue to hold it all in place. Works like a champ for me.
woo hoo pics, yeah seeing the finished product makes me a lot more confident in what I'm doing. I was pretty sure that it would look like, but its nice to know for sure. Thanks for the pics!
http://www.cardomain.com/ride/2625515/8
By no means am I an electrical whizz.. so if you have comments about it good or bad, i'd be glad to hear.
Thanks.
or instead of ripping apart a serial cable, you can just buy a D-Sub connector and connector hood from radio shack.
http://www.radioshack.com/product/in...ductId=2103993
As far as making this cable work under Vista.... Yes, it does work. Copy the installation files from the little CD that comes with the Dynex cable onto ur desktop. Right click the setup file and run it in Windows XP compatibility mode as an administrator. Reboot and plug in he cable. DO NOT plug in the cable prior to installing the drivers
Mine's working like a charm
I also got my cable working in Vista.. It was actually my USB adapter that was causing me grief. Next task it to get maptracer to work =/
